Best budget (400Eur/pc max) compression driver May 2020? Suggestions, please.
There are certainly some new models available. My budget is 400 Eur/piece maximum. Currently I have a pair of Beyma CP385Nds and BC DE500s. I really like the integrated driver of Beyma 12XA30. I would like to have extension as high as possible and as low as possible for HiFi application and high sensitivity. 1.2 kHz or lower. Exit size does not matter. It will be used with a midbass and bass horn or in a synergy style horn.
Oberton and Eminence are both offering carbon fiber based diaphragms with good overall performance at lower prices.
N314X-8 - Drivers | Eminence Speaker
ND72HB
ND72HB
You already have two good 1" compression drivers, and a new-tech 1.4" CD would have a falling SPL above 15kHz. Have you given any consideration to experimenting with a 1.4" exit coaxial compression driver like the BMS 4594Nd-E or B&C DCX464 which measure well between the 400-18.000Hz range? They cost between 500-600Euros, but could provide an excellent in-room sound with fewer/simplier bass and subwoofer. The fiberglass SEOS24 horn(24" wide. 1.4" entry) measures well over this range, and you might find a used pair around your country.
SB Acoustics new Audience line has some CD's (and horns) that look nice.
Here's the BIANCO-44CD-PK on their H250 horn....
I'd say that not all coaxials are out of the budget.
BMS 4590-16 – Thomann Česko
Priced under 400€/piece i think they are the best out there for that amount of money.
That actually looks quite clean. However it seems to drop of at 650Hz already, while they quote it usable from 300Hz. Could be the horn they used.
It is basically the same driver/performance as 4592 only ferrite magnet, so heavier - 11kg/piece
Yeah, I figured. Saw them even for 340,-/piece.
Seems like off-axis falls off quite quickly after 10Khz, as one would expect from a 2" exit.
ND72HB
Considering the low distortion at the recommended crossover point of 800Hz the N314X-8 could be pushed lower in frequency if you don't need full output.
Is it going to be 3D print?synergy style horn.
The Eminence looks good. I will have a look at the ND-350.
1hiep0: Most probably yes, unless my DIY CNC router will be finished before I start this project[/QUOTE
Regarding the Eminence...
I suggest waiting for independent test results where we can see frequency response graphs that aren’t smoothed. It appears as though Eminence has used 1/3octave smoothing which completely erases dips and peaks caused by resonances. It might sound good or it might not. There’s no way to tell from the published data.
- Best budget compression driver May 2020? Suggestions, please.
