Best budget compression driver May 2020? Suggestions, please.
Joined 2008
Best budget (400Eur/pc max) compression driver May 2020? Suggestions, please.
There are certainly some new models available. My budget is 400 Eur/piece maximum. Currently I have a pair of Beyma CP385Nds and BC DE500s. I really like the integrated driver of Beyma 12XA30. I would like to have extension as high as possible and as low as possible for HiFi application and high sensitivity. 1.2 kHz or lower. Exit size does not matter. It will be used with a midbass and bass horn or in a synergy style horn.
You already have two good 1" compression drivers, and a new-tech 1.4" CD would have a falling SPL above 15kHz. Have you given any consideration to experimenting with a 1.4" exit coaxial compression driver like the BMS 4594Nd-E or B&C DCX464 which measure well between the 400-18.000Hz range? They cost between 500-600Euros, but could provide an excellent in-room sound with fewer/simplier bass and subwoofer. The fiberglass SEOS24 horn(24" wide. 1.4" entry) measures well over this range, and you might find a used pair around your country.
SB Acoustics new Audience line has some CD's (and horns) that look nice.
Here's the BIANCO-44CD-PK on their H250 horn....
:cheers:
I'd be ready to accept the fact that my horns have to be pointed at my listening position for what i get in return (point source from 300Hz with acoustic centers aligned at all 3 axes, no breakup at +10kHz characteristic for most 2" exit non coaxial drivers).
The Eminence looks good. I will have a look at the ND-350.
1hiep0: Most probably yes, unless my DIY CNC router will be finished before I start this project🙂[/QUOTE
Regarding the Eminence...
I suggest waiting for independent test results where we can see frequency response graphs that aren’t smoothed. It appears as though Eminence has used 1/3octave smoothing which completely erases dips and peaks caused by resonances. It might sound good or it might not. There’s no way to tell from the published data.
