Beautiful build Dijwim. Im curious to know how you managed to secure the top plate the the rest of the chassis? I see holes in the chassis, bit not on the top plate
Thanks for your comment .
Both the front plate and the top plate are glued on top of another aluminum plate that holds the screws. This way all screws are invisible, but still a tight fix.
I would love to see a pic of what you mean, cant quite picture it.
here you are, a pic of the underside of the top plate
So the top plate just sits on top of the enclosure (it is not screwed)?
By the way: fantastic build !!
Yes for the moment it is not screwed on. But it is a tight fit and I need some force to place or remove it. So if I hold the amp upside down it doesn’t fall off.
But there is a way from the bottom side to place the nuts and tighten the screws.
And thanks!
so you have double plates at the top, and you tighten it from below?
Yes. It is not easy, so for now it is just sitting on top. But from below I can place the nuts and tighten it.
...So after a lot of sawing, bending and sanding I am happy to share the result of the build.
Well, when I saw, bend and sand it does not look like this...
Great work!
Great work!
Thanks a lot
Superb build Dijwim!!
Congratulations!
(I notice a lot of the stuff built by the Dutch guys is done to a very high finish)
Many thanks!
BA1200 Corona Edition in progres
I like your finish, one special detail, put the input in the front, also you can put the output and the switch. We all the time are connecting and reconnecting our equipment, since long time ago I use this disposition.
Best Regards
Very nice! Congratulations!
- Post your Solid State pics here
