Post your Solid State pics here
relay attenuator development of my compatriot Maxim Volobuev. Assembled on takamisawa bistable relays. The case, pcb, are developed by me comprehensively, transformers are wound to order.
There are three versions of cases and layouts, 65 mm, 130 mm and 160 mm high. 160mm version for 2x200W amplifier or computer.
Hello, I want to share my build of the honeybadger amp. After building and testing the boards it was time to build a nice case to hold the amps. I decided on a design that is very much inspired by Cambridge Audio. So after a lot of sawing, bending and sanding I am happy to share the result of the build.
Reactions: Ciro82
