The BA-3 as preamp build guide
Thanks Jim.
I'm Billy. So far I've built an F5 and an 834 phono stage. Frugal horns and a heavily modded Lenco TT. But... I had a pretty severe stroke in 2018 and I get big brain farts. Leading to confusion.
This forum feels like a place where I can get good advice.
I believe everything should be clear if you read datasheet of xformer
having separate secondaries and connecting them to have CT is much easier that the other way around
here's some help
ignore miss-type here and there
if you have datasheet, post it here
duh
no color info there
what wire colors you have , one secondary, second secondary?
usually, start of winding is one color, end of winding other color
say that you have green and yellow
green 1 : first secondary out (to diode bridge)
yellow 1 + green 2 : Center Tap (GND)
yellow 2 : second secondary out (to diode bridge)
checking is easy , by sketch I uploaded ; connect two wires from different secondaries, put Vac meter across free ends,power up Donut ( taking all safety measures - isolated mains contacts etc.), measure ; if you have double Vac , that's the arrangement ; if you have nearly 0Vac , change place of wires of one secondary, retest
duh
no color info there
I understand. Thank you.
They are ClarityCap CSA bought at HiFiCollective.
I went ahead and put these caps on the outputs of both my Pearl 2 and BA-3 FE, replacing the electrolytics and film bypass. 2.2 uF is all I need based on input impedances. I listened for a few minutes and my initial impression is positive, I'll try to do a longer session tonight.
Don't laugh at my BA-3, I mistakenly bought components that are oversize and crammed them in. 😛
y4mFAGxsbRi55GAX6rrTM0mTQ7wrmPcnanYfTzTtKQroBJGpreOwQZHSyXvFDGLc0ILobI9mw6HjSnlX0rPuUMw1R2rrYrb-Y0f2MinQmgOUKn6CUSY59C7hHiED_qyC2StuqzCI7Cy69NrWYFS4qMRWpiHEYuIB2Ixlyf4YegPZrDvt-7LVm7r-T4wI2gEdVfuQZ2xaOrL2JQCPRfWvN7Dfw
