You are very right.
For test I installed very fast fuses (500mA) between the amp and speakers. Currently building the protection circuit.
I use large capacitors as 10000uf,between amplifier and speaker, for test.
Also a good idea. One of the advantages of building with tubes is always the output transformer. Very safe 🙂
What voltage for those caps?
63V is fine for most of diy amplifiers.
If there's any possibility, I'd turn the right HB board on your 6th pic upside down for improved cooling efficiency. The power devices should be mounted as low as possible, I think 😉.
Best regards!
Best regards!
Congratulations!
Very professional work! 😎
Yes, I agree in terms of professionality!
May I ask which housekeeping boards you did use?
Best regards!
Best regards!
The honey badger boards are a clone made by Juan vargas which I modified slightly when he was teaching me how to use Sprint layout. We both worked together on the main power supply board and the speaker protection boards while he continued to teach me Sprint layout. I then created the soft start board, the Amplifier control board, the ground lift board and the T-GND boards myself. The soft start board is unlikely any other as it first verifies that there is actually a intacted load resistor before it actually being the soft start process.Yes, I agree in terms of professionality!
Best regards!
I also design the case myself.
Good looking Stuart,
That internal wiring, routing of cables, heat shrinking takes a LOT of work !!
And the planning of layout, lots of work.
Bonsai help me plan the wiring layout. His guide is very informative.Good looking Stuart,
How to wire up an Amplifier
I guess it's long over due that I check back in here 😉 .
I had all my PCBs assembled and ready to go into my 5U deluxe case, and then I tore down my house, and had a kid!
I'm hoping to go through my badger box and figure out what I need to order to finish this up! I know I need some metric hardware, standoffs, and a few other odds and ends. Should I do a slow charge on the PSU caps? They were stored (on the PCB) for approx. 3 years. I only know this because my son just turned 3.
I'm still planning on a 21st century protection as well. Will update as I make progress, which hopefully moves faster than the last 4 years🙂
Cheers!
Cheers!
Cheers!
It's a good idea to reform caps that have been sitting around for a while.
We've added some optional bells and whistles to the 21'st century protection system. It can now interface with a front panel display and IR remote control.
That's great news! I'm glad to see things evolving! Once I get the HB running, the 21st century protection is next in the list. I'll see what other cool features I can add too.
Is the efficiency of the honey badger around 43%?
how did you measure?
- diyAB Amp The "Honey Badger" build thread
