Develop ultra capacitor power supply and LiFePO4 battery power supply
Why not build one ? This is diy, and fun. My psu with R-Core and LT-3045 regulators.
Total solution: UcMateConditioner + UcHybrid + UcAdapter
I'm busy working on the ultra capacitor upgrade total solution, which are:
1. UcMateConditioner (5V)
2. UcHybrid (3,3V each, capable for 13.2V when more boards are used)
3. UcAdapter PCB
This total solution will work seamlessly for LifePO4 MKIII. It can also work for MKII. The screw positions may not match MKI very well.
UcAdapter PCB will be installed on top of LiefPO4 MKIII or MKII.
UcAdapter PCB also has two shield layers.
More update will be posted soon.
UcUpgradeSolution2
by Ian, on Flickr
UcUpgradeSolution1
by Ian, on Flickr
Ian
Seeing Ian's progress has prompted me to post my take on his battery/ultracap combo. This is now up and running and the ultracaps add texture to the bass, especially cellos. This supplies power to the M Scaler for two hours when fully charged at 13V. I have another battery board (damaged) that Ian has offered to repair that will double run time. Once I get this sorted, I will box it all up in a Takachi case; a very tight fit. Photo of box doesn't show top board added.
Hi Ian,
Your UC solution looks interesting. From your testing indicating short distances and thick wires are best between the batteries and UCs, I thought you may have exploited the opportunity to direct connect the UC board to the battery board using headers and footers to the slots connecting the batteries on the battery board.
Martin.
@hibo4
You integration looks awesome, Very professional! You did good job!
Did you pre-charge each ultra capacitors?
Ian
Hi Ian,
Charging the UCs was both simpler and more difficult than expected. My Plan was to connect the empty battery board and charge each set with the lifepo charger I have. Unfortunately, the charger couldn't see any batteries so I charged them with a 3.3V power supply. Once the UCs had a couple of volts, I could revert to the charger. What surprised me was that all the UCs charged together. The process took about three hours.
Martin
Amazing work!
Hi Ian,
This looks promising.
How will the connection to the battery board be made? As short and thick leads are important to get the best out of the super low impedance of the supercaps, this seems to me one of the most important design choices.
Would it not be better to put this board up side down below the battery board so very short leads are possible?
UcMateConditioner
Functionally UcMateConditioner is exactly as same as UcConditioner. The difference is that it was designed dedicated to the LifePO4 power supply through UcAdapter PCB. It works directly with MKIII, as well as MKII.
UcMateConditioner uses low ESR MOS FETs rather than the relays to improve the performance. By connecting to the control signal from the LifePO4 power supply board, they will work together seamlessly.
The first picture is the UcMateConditoner boards.
The second picture is how it is mounted it to the UcAdapter PCB
Maxwell/NESSCAP BCAP0325 P270 S17 is confirmed to be the best performance because of the lowest ESR so far. Other ultra capacitors can also be used, such as BACP0350 E270 T11.
UcAdapter PCB will be installed on top of the LifePO4 power supply. It also has double shield layers.
UcMateConditioner1
by Ian, on Flickr
UcMateConditionerUcAdapter
by Ian, on Flickr
Ian
@paoloilpizzo
I'm working on a couple of projects now.
1. LifePO4 MKIII
2. UcMateConditioner (5V)
3. UcHybrid (3.3V, capable for higher voltage if use more)
4. UcAdapter PCB
5. ConditionerPi (5V)
5. UcConditioner (5V)
I'm trying my best to make them available soon.
Ian
thank you !!
imagine that there are several such boards. will it be possible to control on and off centrally? Is there a mechanism and solutions for this?
LifePO4 power supply MKIII
New LifePO4 power supply MKIII was fully tested without problem.
The improvements to the MKII are:
1. Ready upgrading to ultra capacitor power supply by integrating with UcMateConditioner and UcHybrid.
2. New continuous DC 5V mode can be enabled now.
3. PTC fuses replace the protection resistors to reduce the risk of possible damaging and reworking.
4. New optimized PCB layout and the double thickness copper layers lower the power supply ESR even more.
5. Accuracy of voltage measurements and monitoring were increased.
6. Can have up to six outputs of 3.3V LifePO4 voltage rails in total.
PCB size was increased a little bit but all mounting holes are still compatible with MKII.
LifePO4MKIII1
by Ian, on Flickr
LifePO4MKIII2
by Ian, on Flickr
LifePO4MKIII3
by Ian, on Flickr
Pleas do take care under this COVID19 situation!
Ian
