Which is most most musical of all the sit
Tuby
hard question ... in fact easy , when you ask it on some fifi forum , not here
if you did ask , which of SITs is best , taking in account linearity , dissipation and all tech factors , then it's easy - 2SK77B is most probably best of all , easily implemented in whatever arrangement you can think of
not even counting fact that Pa said "this one is The Best"
with Singing Bush type of amp , result heavily depends of amp-speakers marriage; even if 45-50W is respectable for SE amp , you need sensitive and efficient speakers to use all raw and triodish quality of amp , while keeping it in lowest possible power range (using rest for dynamic peaks) , so having least possible THD
same applies to any tube SE amp ......
so , it is really more question of fact what you have (of SITs) on your bench ; if 2SK77/2SK77B then no brainer ; if THF51/2SK182ES then there is little more compromise
we'll see what we are getting with 2SK180 ; though - even if I'm hoping , I'm really not expecting miracles
if you don't have 2SK77/2SK77B and you vary of compromises , just make Schade iteration ...... that one was more cunning from Pa than primary one (with 2SK77B) , meaning - it's easy when you have jewel in your hand , while its harder to make jewel from brick
Pa, Mithrandir , Funny Alchemist
we'll see
my own personal Wakootalian , Mighty Bubba Flocchini , sent me a pair of these for testing
now they're on Customs , hope to get them sooner than lately was the case with lazy bstrdz
everything will stay the same , possible variations voltage potential of SIT Drain and values of resistances in Mu source
we are hoping that bloody thing is similar to 2SK77B , and as we all know , hope is dying last .......
while mine , from Bubba Flocchini, are still Customized , got them suckers , freshly arrived to my (local) Buddy
will spend some time these days to test them , and after arriving of second pair , will test these too
as I said - hope never dies - we'll see how they're close to The Best Ones
Awesome thread and thanks.as you probably know , I was on Pilgrimage (end of last year) to Sea Ranch .... to have few walks by the Open Ocean , collect some wood flown to shore ..... and to remind Pa that life isn't serious thing at all
Very nice to see yous standing together and very wonderful to see yous SIT'ing together too!
Very cunning indeed!as Pa is getting ......... wiser , it seems he's developing tendency of becoming more serious
so , it'll be cunning to visit him annually , to prevent further increase of seriousness
that's very cool
can't wait to see the results
Lazy Sunday .......
so no testing 2SK180 today
maybe tomorrow , but most probably day after
in a meantime , here's Trade post : The Singing Bush Kits
think hard - do you need it , are you happy with 130-180W of heat per channel...... which iteration is right for you etc.
....contrary to some latest concoctions , this one is easy to set and forget , but as any , it demands patience and care in assembly
Choky,
I ordered the Singing Bush kit because we don't have enough heat in Arizona
Can't wait for those 180 measurements....no pressure.......
2SK180: Hope never dies ....... but, Oh Boy , how it's Dodo now!!
pair sent by Bubba Flocchini are still Customized , and I did put today first one (of pair) my local Buddy obtained
initial setup , as hope (that it's close/r to 2SK77B) commands , same as ZMighty Singing Bush - rail 60Vdc , Iq 3A, Mu resistor set 0R2 up, 0R2 down, speaker output from middle ,Drain potential smidge bellow 30V
first stint - 1W THD Spectra measurement - damn!! 1.76%
power down , insert additional 2pcs of 0R1 in Mu string , power up , set Iq to 2A2 , Drain at 35V , try THD with 0R4 up and 0R2 down , then with 0R2 up and 0R4 down
THD shows that better option is 0R4 up and 0R2 down
few pics of setup
few pics of setup
2SK180 Singing Bush , 8R load
gain is 330mV in for 2V828 out , so 8.57V/V , 18.66db
2SK180 Singing Bush , 4R load
gain 338mV in for 2V out, so 5.917V/V , 15.44db
2SK180 Singing Bush, conclusion
well , behavior pretty much the same as THF51 and 2SK182 , maybe little more leaning to 182 side
was it worth spendiong money and repeating all measurements , to find out how hope is mortal?
considering that this time I didn't engaged my wallet, ( as was the case with 2SK182 for SissySIT)first part of question my Buddy and B. Flocchini need to answer
measurements - it was my pleasure , as always is , when I have something to play with
hope is maybe mortal , but we Kids are immortal !
one thing more - if you look back at what's posted in #57 , my fave commercial toob amp - EAR 859 - situation with any iteration of Singing Bush is simply more rosy
and , THF51/2SK180/2SK182 iteration , being slightly scaled down to 132W of heat per channel , is somewhat easier to make , as little bonus to decrease in performance , when looking at ZMighty Singing Bush with PapaTokins
I will repeat measurements , probably tomorrow , with second 2SK180 specimen , but now really not expecting Miracles
Choky,
well , contrary to Jim , who's flying those sissy little jets for diamond clientele, you can make a pair of these and put in your cockpit
"was it worth spendiong money and repeating all measurements , to find out how hope is mortal?
considering that this time I didn't engaged my wallet, ( as was the case with 2SK182 for SissySIT)first part of question my Buddy and B. Flocchini need to answer "
It's all part of the experiment and what was learned
no regrets here
Will do the Singing Bush with THF-51S guessing 180s will find a home in another build (always optimistic
Thanks ZM for all the effort !!!!
no regrets here
And since I am a spoiled pilot, I'm going to ask you to go a bit farther with you measurements. I have a 4 ohm loudspeaker, can you look at different rail voltages for 4 ohm load to see what rails would give me best case H2 scenarios? I realize the VFets are going to be different. And on that note, I wonder if the higher VGS parts do better with H2 dominance.....
- The Singing Bush
