The Singing Bush
Official Court Jester
Joined 2003
Which is most most musical of all the sit
Tuby
hard question ... in fact easy , when you ask it on some fifi forum , not here
if you did ask , which of SITs is best , taking in account linearity , dissipation and all tech factors , then it's easy - 2SK77B is most probably best of all , easily implemented in whatever arrangement you can think of
not even counting fact that Pa said "this one is The Best"
with Singing Bush type of amp , result heavily depends of amp-speakers marriage; even if 45-50W is respectable for SE amp , you need sensitive and efficient speakers to use all raw and triodish quality of amp , while keeping it in lowest possible power range (using rest for dynamic peaks) , so having least possible THD
same applies to any tube SE amp ......
so , it is really more question of fact what you have (of SITs) on your bench ; if 2SK77/2SK77B then no brainer ; if THF51/2SK182ES then there is little more compromise
we'll see what we are getting with 2SK180 ; though - even if I'm hoping , I'm really not expecting miracles
if you don't have 2SK77/2SK77B and you vary of compromises , just make Schade iteration ...... that one was more cunning from Pa than primary one (with 2SK77B) , meaning - it's easy when you have jewel in your hand , while its harder to make jewel from brick
Pa, Mithrandir , Funny Alchemist
Joined 2003
we'll see
my own personal Wakootalian , Mighty Bubba Flocchini , sent me a pair of these for testing
now they're on Customs , hope to get them sooner than lately was the case with lazy bstrdz
everything will stay the same , possible variations voltage potential of SIT Drain and values of resistances in Mu source
we are hoping that bloody thing is similar to 2SK77B , and as we all know , hope is dying last .......
while mine , from Bubba Flocchini, are still Customized :rofl: , got them suckers , freshly arrived to my (local) Buddy
will spend some time these days to test them , and after arriving of second pair , will test these too
as I said - hope never dies - we'll see how they're close to The Best Ones
Joined 2003
Lazy Sunday .......
so no testing 2SK180 today
maybe tomorrow , but most probably day after :)
in a meantime , here's Trade post : The Singing Bush Kits
think hard - do you need it , are you happy with 130-180W of heat per channel...... which iteration is right for you etc.
....contrary to some latest concoctions , this one is easy to set and forget , but as any , it demands patience and care in assembly
Choky,
I ordered the Singing Bush kit because we don't have enough heat in Arizona :D
Can't wait for those 180 measurements....no pressure.......;)
Joined 2003
2SK180: Hope never dies ....... but, Oh Boy , how it's Dodo now!!
:rofl:
pair sent by Bubba Flocchini are still Customized , and I did put today first one (of pair) my local Buddy obtained
initial setup , as hope (that it's close/r to 2SK77B) commands , same as ZMighty Singing Bush - rail 60Vdc , Iq 3A, Mu resistor set 0R2 up, 0R2 down, speaker output from middle ,Drain potential smidge bellow 30V
first stint - 1W THD Spectra measurement - damn!! 1.76%
power down , insert additional 2pcs of 0R1 in Mu string , power up , set Iq to 2A2 , Drain at 35V , try THD with 0R4 up and 0R2 down , then with 0R2 up and 0R4 down
THD shows that better option is 0R4 up and 0R2 down
few pics of setup
Joined 2003
2SK180 Singing Bush , 8R load
gain is 330mV in for 2V828 out , so 8.57V/V , 18.66db
Joined 2003
2SK180 Singing Bush , 4R load
gain 338mV in for 2V out, so 5.917V/V , 15.44db
Joined 2003
2SK180 Singing Bush, conclusion
well , behavior pretty much the same as THF51 and 2SK182 , maybe little more leaning to 182 side
was it worth spendiong money and repeating all measurements , to find out how hope is mortal?
considering that this time I didn't engaged my wallet, ( as was the case with 2SK182 for SissySIT)first part of question my Buddy and B. Flocchini need to answer
measurements - it was my pleasure , as always is , when I have something to play with
hope is maybe mortal , but we Kids are immortal !
:clown:
one thing more - if you look back at what's posted in #57 , my fave commercial toob amp - EAR 859 - situation with any iteration of Singing Bush is simply more rosy
and , THF51/2SK180/2SK182 iteration , being slightly scaled down to 132W of heat per channel , is somewhat easier to make , as little bonus to decrease in performance , when looking at ZMighty Singing Bush with PapaTokins
I will repeat measurements , probably tomorrow , with second 2SK180 specimen , but now really not expecting Miracles
"was it worth spendiong money and repeating all measurements , to find out how hope is mortal?
considering that this time I didn't engaged my wallet, ( as was the case with 2SK182 for SissySIT)first part of question my Buddy and B. Flocchini need to answer "
It's all part of the experiment and what was learned
no regrets here
Will do the Singing Bush with THF-51S guessing 180s will find a home in another build :D (always optimistic
Thanks ZM for all the effort !!!!
well , contrary to Jim , who's flying those sissy little jets for diamond clientele, you can make a pair of these and put in your cockpit
And since I am a spoiled pilot, I'm going to ask you to go a bit farther with you measurements. I have a 4 ohm loudspeaker, can you look at different rail voltages for 4 ohm load to see what rails would give me best case H2 scenarios? I realize the VFets are going to be different. And on that note, I wonder if the higher VGS parts do better with H2 dominance.....
