Bob Cordell's Super Gain Clone PCB (LM3886) and a stripped-down version: Compact3886
this is an unsupported modification of Bob Cordell's design and NOBODY supports it. NO BODY. Nobody answers questions about it. Nobody helps people who can't get it to work
You are on your own, kiddo. Proclaim it proudly. Best wishes for flawless success.
Maybe you could whine and wheedle and pester Bob Cordell into offering his opinion about your ideas, but that would be a little tawdry IMO.
_
One trick you could experiment with is altering the noise gain.
The chip is stable from gains of 10 upward and so we have to trick the chip into thinking it is running at higher gain when it in fact (for your wanted signal) it isn't.
We do that be adding one resistor between the two inputs. Lets say we want a signal gain of just 5.
The chip now thinks it sees a feedback network of (in this example below) of 5k and 1k as far as signal goes, and that gives us a signal gain of 5000/1000 which is just 5.
That's OK for our signal but way below the minimum gain requirement of the chip. So we add another resistor between the inputs, in this case 500.
The chip now see a 'noise gain' feedback network of 5k (the feedback resistor) and now the 1k is in parallel with our newly added 500 ohm resistor.
How does that work? Well the 500 ohm sees no signal across it because both inputs are effectively at ground potential. So now the feedback network (for noise gain) gives a value of 5000 divided by the equivalent parallel value the two resistors. The 1k and 500 in parallel equate to a single 333 ohm.
Now we get a noise gain of 5000/333 which is 15. The chip is happy as we are comfortably over the minimum of 10.
Does it work? Yes, it works really well and here is a squarewave test of the amp configured in this way. Squarewave testing is really revealing of stability.
If we remove the 500 ohm we can see just how unstable (as expected) the amp has become (last image).
Forgive me if I missed this earlier, but... What is the difference in the performance of the super gain clone and the compact 3886? I was just looking at the parts on Mouser and they are missing a 1k resister that won't be in for a few weeks. Digikey lists it as a special order with a 5 month turn around. And the compact is missing an LED which shouldn't be hard to source. Of course, I bought both boards and 2 PS boards so I can ultimately build both. Just curious at this point. Thanks!!
Bob
I definitely would NOT recommend a TL072 in Bob's Klever Klipper: its relative huge resistors in series with the output, won't give the soft clipping behavior that Bob designed.
I'd recommend NE5532 or NJM5532 or RC4580 or NJM2068 .
_
I'm going to beg to differ here and say that the TL072 (not a TL071 which is a single opamp) would be fine. Those series resistors internal to the chip are within the overall feedback loop which is applied externally.
I like the TL0 series and they can be capable of excellent sonics.
The LM833 is another excellent device but be aware that two versions exist, the old original device and a revamped version with a quasi complementary output stage (imo the one to go for).
About op-amps use.
The chip used for the Klipper part of the circuit shouldn't really have any impact on sonics and the same applies to the chip used for the servo, however the servo opamp should definitely be a FET type such as the OPA134 listed or a TL071 (the single). Both those are perfect for servo duty.
@ Tripmaster
There are quite some versions around. If you have a professional etching system at home, maybe heated foam or the like, do your own. In any other case, buy it finished. Where i live, I can´t even get good photo coated PCB material for the price you pay for a PCB on ebay or Aliexpress.
As long as you use a 200 VA transformer or less, AND as long as you keep the DC voltages comfortably less than the max-V rating of the electrolytic capacitors you buy, then you can use the "PSU for Chipamps" PCB (which has its own thread on diyAudio).
