Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
after modifying, can it be used in balanced output amplifier ?
If you only run one wire from BTL amp through the SSR (+ve amp in and speaker out) and connect the -ve of the amp directly to the speaker without going through the SSR -ve pin (as it is tied to GND and would short our a BTL amp). Then connect the +/- of the SSR power supply to the + PSU and amp GND, it should work. If DC is detected, it will break the connection between the two amp outputs.
Hi Folks,
Just wanted to let you know that things are a bit quiet (no activity from the factory) due to Lunar New Year in China. Now with the Corona virus epidemic and various lock-downs going on, I am not sure how this may affect business where this factory is set up. Will keep you posted though.
X
Is it possible to reduce the DC threshold to switch off? I am considering to use the SSR in a headphone amp, where the 1 VDC threshold is a bit too much for my tastes.
If it is possible: how do I modify the boards? I guess it's a matter of changing some resistors...
We have a HP amp DC offset protection system designed just for headphones that I tested. Works very well. Similar in operation but with smaller components due to lower current requirements and threshold is lower. Threshold is +/-500mV DC. Still low RDSon MOSFET so that sound quality is not affected.
Cheap as Chips OPA1688 Low-THD Muscle Amp
776404d1566273795-cheap-chips-opa1688-low-thd-muscle-amp-hpa-ssr-protect-03-jpg
776406d1566273795-cheap-chips-opa1688-low-thd-muscle-amp-hpa-ssr-protect-schematic-jpg
Hi X
I have pre-ordered 2 units from Etsy
GB update
tcpip 6 units USA
mbrennwa 6 units Switzerland *Pre-order Placed*
Andyr 4 units AUS *Pre-order Placed*
Schlomoff 4 units FR *Pre-order Placed*
jwjarch 4 units USA *Pre-order Placed*
Meanie 2 units Singapore *Pre-order placed*
rebone 2 units Spain *Pre-order placed*
all the best
I finally installed the DC speaker protection boards in my PeeCeeBee V4H. I used the +24/GND Aux output from the Cresnet SMPS to power the protection boards.
Works as advertised!
