Neutriks are for Drillholics
Hahaha
Yeah 4 bloody holes drilled and tapped per speakon connector.
you're not sleepy , down under?
I will be awake for at least another 3 hours.
Just in case people are interested in what I use with regards to wiring and connections.
22759/43-12-9 TE Connectivity Raychem Cable Protection | Cables, Wires | DigiKey
22759/33-22-9 TE Connectivity Raychem Cable Protection | Cables, Wires | DigiKey
342143-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
342183-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
1546670-4 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/1546670-2/A98514-ND/1131448
Nice wire. Guessing 12 for speaker and 22 for signal? How about power from PSU to board? Always curious what other people are using for wiring!
I started out with 16AWG PVC wire, and still use it when I want something stiff. But I've mostly switched to Silicone insulated wire, which is much more flexible (although it annoys me that the colours are very washed out).
I use 32AWG for signal in places that are physically well protected, but 22AWG in most places (the 32AWG just seems to fragile).
The front-panel wires here are 32AWG, but the signal wires going to the volume control are 22AWG:
These are all 22 and 16:
For Jam Jar monoblocks I have some 12AWG for power & output.
Jeff.
Jeff.
Nice!! This is really helpful-thanks for sharing! I really like those bundles on that first image.
Signal: 22 to 24 awg
Speaker: 12 to 14 awg
Power: 12 to 14 awg
I don’t care about the insulation material, but I always use silver or silver plated copper, that usually means it’s probably going to be ptfe, or etfe.
Power: 12 to 14 awg
Thanks for the info! I’ve been using silver plated copper thus far, but am in the middle of some power rewiring and trying some tin plated copper (just what I had available.) Hoping I don’t hear the difference
I don't think you will hear a difference.
I just prefer silver cause it will help me sleep better at night knowing I won't need to be replacing the cables for a bloody long time, if ever.
I have some speaker cables that are green. It's easy replacing external speaker cable, not so easy replacing wire in the amp chassis. I prefer low maintenance.
If I didn't use silver plated, I would use tin plated.
Results of Vgs Threshold (Id = 2.5mA) testing.
ECW20P20
0.53V x 2 out of 20 devices
0.55V x 18 out of 20 devices
ECW20N20
0.14V x 20 out 20 devices
You won’t get this level of matching out of any mosfets I am familiar with.
The whole curves match just as well from my memory of my previous testing results.
I will do complete curves of Id vs Vgs later (maybe tomorrow)
ECW20P20
ECW20N20
What's the part # on those big bridges? I was looking for something similar, but couldn't find anything soft/fast recovery.
Nice shielding on the mains entry.
http://ixapps.ixys.com/DataSheet/VBO52-08NO7.pdf
I don’t know what kind of recovery it has but we will see it in FFT and can compare with the FFT of the soft recovery rectifiers in my previous build.
A friend sent me a link to one that's a FRED:
VBE60-06A IXYS | Mouser Ireland
but dang, those suckers are expensive.
That looks like a nice chunky Ametherm behind it. You using the AS32-20010?
Yeah. I am aware of that one, but I chose vbo52 cause I prefer the package and terminal style of it. I also like the low forward voltage drop. I can always add an RC snubber if necessary, maybe 10 Ohms, 100 nF.
Yeah the thermistors are Ametherm. I can give you the part number if you’re interested, they’re a little different than AS32
Yeah, when you get a chance. I had a hard time figuring out exactly which one would be appropriate for JamJar.
I'm currently of the opinion that the AS32-20010 will be sufficient (over the AS35-20010), but I'm on a bit of a wing and a prayer.
(I'm feeding a 1.5KVA transformer which then goes to 47mF, 0R4, and 47mF on each secondary. Single thermistor in series with the primary.)
MS22 20005 Ametherm | Circuit Protection | DigiKey
I am going with this one. The energy rating is better than CL60 with higher cold resistance at 20 Ohms, but similar hot working resistance to CL60.
I don’t understand their capacitance ratings since I have used over 400,000uF (200,000uF per rail) with CL60 with a 400VA transformer without issues and these are better than CL60.
I am using 500VA transformers per mono block.
I will be testing soon.
- On A Hippie Trail, Head Full Of Zombie
