Babelfish M25, SissySIT - general building tips and tricks
Official Court Jester
Joined 2003
I made this one, and labeled it - for 2 Donuts , each having 1 NTC per primary
so , 2 pairs of input wires , 2 pairs of output wires
with some simple ingenuity , it can be used for whichever arrangement you need it
post sketch of your intended Donut(s) , and I'll edit your sketch to accommodate your needs
SissySit is up and running thanks to ZM
WOW :D
Initial comments Smooth natural sound with deep soundstage
Clamp meter is a jewel
Found these in my stash, tea-bag`s PS boards, so one board for each site (separately L and R channels), four bridge rectifiers, two 2x18 transformers feeding each board, complete independence. I will lift the boards and run the AC lines under all the way to front area where the toroids will live.
Joined 2003
Those are great PS boards. Use them in all my builds except F5, first diy Pass amp. My favorite power supply boards, tea makes them bomb proof.
Russellc
Started to do the adjustments with the help from Song. The left channel behaved and we were able to achieve the 20mV and 0mV input offset but the right side is stuck at 180mV and unable to go down. We used a variac and the input current draw was 400mV which seem high.
Any advice much appreciated.
