Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
1" : 18Sound XT1086
1.4" :18Sound XT1464
Both are not completely diffraction-free, but about the best of what is commercially available.
If you don't mind some beaming, you might want to look at FaitalPro horns.
This one is also very good and only $13:
I had the 2380 clones in this Cornscala. I really liked the SQ of the D405 mid driver. Getting back to the 2386:
attachment.php
attachment.php
Wow, DI 10 at 800 Hz and climbing to DI 20 at 20 kHz.
Contrast that to JBL 2384, a 90 x 50 pattern.
attachment.php
attachment.php
I find the JBL 2384 90 x 50 pattern already too narrow and looking for more of a 100 x 100 CD pattern. I can't imagine the narrow beamwidth of a 40 x 20 pattern of the 2386 in a near field living room scenario. The 2386 is a long throw horn designed for stadiums and arenas...
Ro808, I had those QSC clones with a BMS 1" 4540nd that genuinely made it past 20 kHz and sounded like a tweeter instead of a horn. Should have kept them.
Well I guess this is the dreaded waistbanding. From the pictures on the Speaker Exchange website I would quess the vertical opening to be around 12" which would equal Lambda/2 around 600 Hz.
In the horizontal plane it is less pronounced due to the fact that the vertical (i.e. left and right) edges are less sharp and the width is not constant over the whole height (PT waveguide). But there is still a slight depression a little lower in the diagram, although nothing to worry about.
Charles
...this is the dreaded waistband...
Hi Charles
Yes, horns can waistband but I suspect here the problem is made worse by the vertically stacked woofers in the 4722.
That is what I would like to confirm with Mitch.
He has a 2384 and I hope he has data for the horn alone.
In the horizontal plane it is less pronounced due to the fact...But there is still...a little lower...
You mean the small dip at 400 Hz?
This is below crossover so I think not horn related, maybe some minor contribution.
I think the lack of a waistband in the horizontal plane shows that with careful mouth transition there is minimal problem.
Hence my suspicion that the vertical waistband is, at least in part, woofer interaction.
But you are correct, the smaller available roundover in the vertical plane would increases the horn contribution.
Best wishes
David
I'm pretty sure its the 2382a......we talked about this loudspeaker a while ago about how it has a diffraction slotted horn but its still perceived well, today, even though...
The horn used in the Strauss SE-MF-2 and 2.1 is the JBL 2380A, 90x40° Flat front Bi-radial horn.
The 2382A is 120x40°, which is visible in the widening of horizontal mouth 'walls', a shallower mouth overall and subsequently a longer slot > a narrower angle results in a deeper mouth. For this reason, in the 2386A the diffraction slot is almost gone. In docali's Selenium - a modified 2386A - there's no diffraction slot at all.
Hi Mitch,
40 x 20 is certainly a problem in any system, but 100 x 100 is wider than I think optimal, even in a small room. I would love to be able to use a narrower 70 x 70 device, but there isn't a feasible woofer that can do that except at >> 1 kHz. Hence 90 x 90 seems to be the highest DI that I found feasible to build cost effectively.
