for unipolar supply, look at first B1(just N polarity JFets) iteration and then you can use either 19 or 24V without changes ; take care to not use limiting output resistor ( was 1K in first one)
for proper wiring of Edcor = look at M2 threads
regarding Rin- series resistor is usually much smaller than that one shunting gate to "gnd" , so that bigger one (then) dominates
so , Rin is in range of 1M
if you have more dilemmas , make some effort and post schematic of you r intended combo . MS Paint or any other small proggy is good enough for editing small schematics
I'll see if I can sketch up a schematic of my plan. I didn't realize the M2 wires the Edcor as an autoformer with both windings connected. Edcor makes a 10K:150 transformer, might be good for more gain if wired backwards.
Good morning gentlemen,
Building two Mofo mono block is my new audio project and I start to list all components to order...
I would like to use the best of it and I am feeling a little bit lost concerning resistors ( too many reference, different temp. coefficient, etc)..
Please could you advise me with precise references ( Vishlay n°…)
About heatsink, do you have, please, link to interesting products. I am looking for efficient and beautifull sculptural extrusion. I would like to build attractive design. 🙂
I thank you really much.
Musically yours
TYM
Musically yours
TYM
something like this?
black anodised and dusty
..I would like to use the best of it and I am feeling a little bit lost concerning resistors ( too many reference, different temp. coefficient, etc)..
You do not find such high quality resistors in many commercial amplifiers
https://www.mouser.fr/datasheet/2/427/cmfmil-109690.pdf
Vishay Dale RN60 or RN65 or CMF , RL cost more..
https://www.mouser.fr/Vishay/Passiv...zekj6Z1yzekiwZ1z0zls5Z1yzuosyZ1yzv7erZ1yzveax
@ TYM
This Vishay Dale resistor has great audio quality / specifications / price ratio.
It's easy to spend money on more exotic boutique resistors like non inductive Mills wirewound, Tantalum,Z-bulk foil etc.
but You need experiment by yourself and find conclusion is worth or not.
If anyone is interested in building one i have this laying around.
2x Hammond 193v
2x Meanwell PS
2x Build PCB (mosfet on the backside)
Shoot me a PM with a offer. US only please
Mod note. This has now been sold to mordikai. 24th Aug 2019
2x Hammond 193v
2x Meanwell PS
The PCBs were available at the diyaudio store, but are currently out of stock:
MoFo – diyAudio Store
I see MOT 's recommended as a choke for the Mofo. Off course those would be transformers with a 110 V primary, would an European MOT with a 220 primary be OK? I measured one and DCR is 1,6 Ohm. Inductance I dont know yet.
Because those MOT's are welded, not very firmly, wouldnt it be better to saw them open, rewind with different wire an add an air gap?
If I were you, I would just quick build Mofo with this MOT on a breadboard, and check frequency response and heat dispersion. Watch out high voltage. 😉
Hi I'm interesting to build this MoFo amp. Where I can buy PCB amp.
You might ping JPS64 - he has a very nice MoFo layout on his GB.
Pass DIY Addict
Joined 2000
Yes, someone else did this and posted images some time ago. I'm thinking he reported just using a hacksaw on the poorly welded seams - they open up pretty easily (though, I haven't done this myself).
DCR above 0R5 or so will only lead to more heat than necessary in the transformer.
are you using this Mofo amp with the the Starving Student II preamp?
I wonder if this combination is interesting and how it is sounding...
Have a nice week end. 🙂
Some very very good wirewounds are Vishay Dale NS series. NiCr Ayrton Perry non inductive for the input. I tested them on my modified 30w Hiraga, and they sounded a bit cleaner thand the RN series to my ear.I didn't know wire-wound resistors were that good. Thanks.
Cheers
- Build This MoFo!
