Which 1.4” would u choose Ro808 to pair with the mr 564 and why? Would going for the 1” units still be a suitable choice for better High freq quality? (Noting that the 1” won’t be able to play as low)
You're right Mitch, but we were discussing the classic 4" JBL drivers.
Lol! I'll go back to sleep now 🙂
The Axi2050 is quite special, you might want to scroll through the thread to find out.
Just a glimpse at the diaphragm suffices.
Good night, sleep tight, and don't let the ...
FaitalPRO 1.4" 8Ω Collection:
If you want my personal opinion; I think excessive emphasis is often placed on the top end (15-20kHz), whereas the soul, or heart of the music,
namely the midrange, seems to be neglected.
Around 2010 the Econowave hype was fuelled by 1" waveguide loudspeakers that were brought to market by people like Earl geddes, Wayne Parham
and many PA brands (QSC, JBL etc.).
I am not completely dismissing the concept of a 12 or 15" PA midwoofer with a 1" horn, but there's some "paradoxical engineering" involved.
On the one hand there's the desire to have constant coverage to below 1000Hz and the need to get to 20kHz on the other.
There's more to this, but I try to keep this simple.
Have you ever listened to a 1.75" diaphragm driver around, or worse: below 1000Hz?
If you haven't, Weltersys' High Frequency Compression Driver Evaluation may enlighten you.
He recorded short sound clips of different drivers that can be downloaded.
WRT the MRII 564: this is pre-eminently the kind of horn to be used with a 1.4", instead of ruining the rather unique properties by using an adapter.
I would suggest to scroll through the specsheets of the 1.4" drivers posted above. You'll notice different diaphragm sizes and materials.
1.4" drivers offer the best of both 1 and 2" (exit) worlds.
They usually allow crossover points as low as 700Hz (or lower) and are capable of clean output up to 15kHz.
And this one's for GM:
tuyen, I realize drivers represent a significant investment compared to (the majority of) horns.
If I were you, I wouldn't select drivers solely for the purpose of using those with the Altec MRII 564s, but instead buy something with other options in mind.
Either way, if you'd buy 1.4" drivers, there's a plethora of horns to choose from.
When you look at the HF200's response curve and consider this driver is highly praised, then compare it to the curve of the HF1440,
it's obvious why the latter driver is much anticipated (at least by me).
You are absolutely right. But why not choose 16 ohm drivers?
This might be a better match with 15“ woofers in terms of efficiancy or usind a tube amp as horn amp (bi amping) or more options for flatening the impedance like paralell resistance.
Good point.
I chose to upload the specsheets of the 8Ω versions only, because Faital doesn't offer the 16Ω option with each driver.
BTW, aren't you one of those "happy HF200 owners"? 😉
Good point.
I chose to upload only the specsheets of the 8Ω versions, because Faital doesn't offer 16Ω variants of every driver.
HF1440 only 8 ohm, my favorite driver 🙂
I see. Thanks for your thoughts Ro808.
I think I like the HF1440 datasheet the most if I had to choose from the lot from Faital. I cannot find it for sale online anywhere though..
The Beyma 1.4" plots seem impressive and similar to the 1440 too?
Beyma Speakers - Beyma CP755Ti - Beyma CP755Ti 1.4" high frequency compression driver. Beyma CP755Ti 1.4" high frequency compression drivers are available here. Beyma speaker components.
Beyma high frequency 1.4" compression drivers - Beyma CP755/ND - Beyma CP755/ND 1.4" high frequency compression driver has a lightweight neodymium magnet. Beyma CP755/ND 1.4" high frequency compression drivers are available here. Beyma speaker compon
Yes that's a nice driver as well, though the factory curve is probably slightly dressed up.
10 years ago, member Lindell built a nice 2-way tower using the 755Ti, Beyma TD385 Horn and a 10" PHL 3002.
The thread is called: Flatter than flat.
This is a preview:
This is a preview:
- Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
