50w Single-Ended BAF2015 Schade Enabled
Maybe it's because I never used other software, but I found KiCad easy to pick up. I couldn't get the modelling to work. I ended up having to build a completely different schematic and at that point figured I should just use LT Spice instead.
I also used this place for boards. Not the cheapest, but quick and good quality. You can literally just import your KiCad file and it grabs what it needs!
OSH Park ~
Plus they're purple 😀
Here's a little surface mount RIAA board I made. Phonoclone circuit tweaked a bit for my application.
OSH Park ~
So far I don’t find KiCAD too bad. I’m going to take my first dip into the PCB pool by doing the bias circuit for this amp pictured a few posts back. A quick, easy, first project to see how things go. More later......
Dan :hot:
Excuse me, if the preamplifier is capacitively coupled output, does the primary input transformer need to be connected with a 10K resistance to the ground? Thank you.View attachment 771403
YES but it´s not always 10K sometimes is less Ohm's resistor.
You need find optimal good component resistance. Please see Mr. Pass answer
