100W Ultimate Fidelity Amplifier
I use NE555 together with the A40 but protection it's too sensitive
to ten percent of the volume goes into protection
without connecting PRO everything is OK
what changes should I make to reduce sensitivity?
Thank you!
Thank you!
You must add overload detect circuit if you want use DC555 proect with A40, like this for SR300.
I have connected as in the drawing:confused:
now it's too late to make changes
It remains like DC and thermal protection
i bealeave that when one people make a diy amp....that must be work properly...with no problem's .....because i expend my time's and my money.....now i not happy with fh11....wish i made another holton 400watt ...:sorry:
I recently built up a new design amp.
It had dc instability but I just put it down to having extra driver transistors.
In the end it was bad current source resistor ! I only found it by accident when I varied its value a bit to try to make it more stable.
I replaced the resistor and it is now very stable.
