hi Mr. Prasi, for the potentiometer (P1) which type should I put? , I can't understand it! body type?
Yes I have built it. Works well. Here are the files.
Hi Still, can you post the electronic diagram of this.
OK I see. I thought you built an A40 for yourself. Nothing wrong with the A33. Beautiful amp.
hi still4ggiven.i made fh11 with 3pair irf640/9640
every things be good..but when power on for 3 to 5 second i have hom noise and pop up!!
please help me...i check circuit step by step..i cant fix this..
what i do?
what i do?
I couldn't fix it either. I used a speaker protection with a delay to solve it. I never installed it into a case. Too many amps.
I use NE555 together with the A40 but protection it's too sensitive
to ten percent of the volume goes into protection
without connecting PRO everything is OK
what changes should I make to reduce sensitivity?
Thank you!
How did you conected this protection to the Apex A40 amplifier ?
Thank you!
You must add overload detect circuit if you want use DC555 proect with A40, like this for SR300.
its means that you have this problem too with fh11?
i made veryy amp such as holton 400 watt ....but i dont any problem
regards
i bealeave that when one people make a diy amp....that must be work properly...with no problem's .....because i expend my time's and my money.....now i not happy with fh11....wish i made another holton 400watt ...
I have connected as in the drawing
now it's too late to make changes
It remains like DC and thermal protection
I recently built up a new design amp.
It had dc instability but I just put it down to having extra driver transistors.
In the end it was bad current source resistor ! I only found it by accident when I varied its value a bit to try to make it more stable.
I replaced the resistor and it is now very stable.
Thank youCongratulations fuego.
Please tell me where I can buy these arrows.
I need 4 pieces.
VU Meter Header DB Pegelmesser fur Onkyo M-5000R HIFI Endstufe | eBay
Very nice! Love the clear top to show off the DIY. Need some better speakers for such a fine amp.
I'm not crazy about the metal speaker jacks. I used them before and blew the outputs when a misplaced piece of metal fell on them and shorted them.
Ouch!
Fuego, very good looking amp, but have you maybe thought about ventilating holes in the top of the cover ?
- 100W Ultimate Fidelity Amplifier
