As long as the corners don’t change the path length or CSA too much.
Thanks, yes the cutoff corners would start behind the internal structure.Will get some ply tomorrow , sketch it up,and start cutting
I was a skeptic but I really like my double 3FE25 Karlsonators.
How much lower bass could we expect with a 4X 3FE25?
Has someone already done a sim for that configuration?
Greets,
Klaus
My experience with the dual 3FE25 Karlsonators is that they benefit greatly from adding a subwoofer (or two) to the system.
I am always puzzled by the idea of adding subwoofer or tweeter to a system. If you do so then you change the whole idea and philosophy of the project, you make it a different project, then you got to compare it to similar projects and start rethinking the whole thing as you may find better solutions.
Most fullrange speakers will benefit from a sub if you want to hear stuff below 100Hz at a louder SPL. Bass down there is all about moving lot of air. A fullrange just can’t move that kind of air unless it is a BLH - which amplifies the low frequencies by providing acoustic gain via proper impedance matching between the cone and the air column. The Cornu horn for example has such bass gain as it has a very large expansion ratio offered by having 4 horns attached to its backside. But even then, no 3.5in or 5in BLH beats a good dedicated large area sub driven by a dedicated amp for punch below 50Hz. The nature of the fullrange sound from 500Hz to 5khz will still be the signature of the fullrange driver.
If you want a bit more bass, dual TC9FD in parallel have more reach. You might be able to swap out the drivers with the same holes even.
Most fullrange speakers will benefit from a sub if you want to hear stuff below 100Hz at a louder SPL. ....
.....Yes....but you make it a different project, you might turn to a two or even three ways project then and you'll probably get better result.
I had the single version of the 3fe25 and the double configuration definetly reaches lower.
Bigger box, longer pathway, more square area of mouth all contribute to lower tuning.
Why wouldn't another doubling of cone area exhibit similar results?
I am just asking, I have little experience with this type of enclosure.
Klaus
Yes, increasing the number of drivers makes the box bigger, an the TL longer, so the bass extension does go lower. 4 drivers would be more like a 0.72 scale or so. Mybe 5Hz to 7Hz lower.
I made some BSC’s with a 1mH steel laminated plate core inductor and a 3R resistor today. Hooked it up to my dual 3FE25-16 Karlsonators. Couldn’t really hear a difference in any bass enhancement. Maybe needs more like 4.7R or 6.8R before noticeable bass enhancement occurs. The steel core inductors are much more compact and lower cost than air cores. I don’t think they sounded detrimental at al.
I’m currently running my dual 3fe25 mini-k’s with BSC at 1.05mH and 6.6ohms resistance. I had a notch filter at about 15-20k but I took that off and have a little more perceived air up top again. VERY happy with the balance I’m hearing currently with just the BSC.
Hi Jwjarch,
I will try the 6.6ohm and 1mH BSC then - looks like I could not hear a difference because not enough highs were attenuated.
Thanks,
X
Thanks,
X
Let me know what you think X. I also tried with 2mH and 8 ohms. The low end sounded full but a little bloated. That was too much. I think there is a balance to be struck with the foam core boxes too. I’m getting a little too much resonance at certain low frequencies so I that’s why I’m going with the 1mh and 6.6ohms as well. Curious to hear if something different works better with your fancy plywood boxes too. 😉
I'm glad that you're discussing BSC's again. I've used 0.9mH + 2.5 Ohm BSC's on my dual 3FE25's, but took them off months ago. I just missed the crystal clear highs too much, although on some tracks, e.g. Katie Melua's I'd Love to kill You, it hurt my ears a bit. But for most other music I've become used to the highs.
Right now I'm busy reading up on miniDSP products and was wondering if that route will be a better answer to this problem. And of course, it'll probably help with sub integration too.
Hi all,
I am midway through building these with the dual TC9FDs. I have two questions.
Has anyone here built the Nola Brio Trio clone and compared the two? I have built the Nola Brios and like them very much. I am interested in comparisons between the two.
The other question is ...how would the Karlsonator work with a Mark Audio 10p? I have a pair of these and really like them. I have seen others build a 6" version for other full range speakers.
Thanks in advance.
Thanks in advance.
I have the Brio clones and the mini-Ks.
The mini-Ks are not bass monsters, but they will be satisfying enough for a wide musical range. Using the aperture, they seem to project the sound farther.
The Brio clones have more ambience to them, more intimate feel, but they are a bit bass shy and really need a subwoofer (or two) to shine.
I have a pair of Alpha 15a in h-frame that I use for bass. I have been using the Mark Audio 10p on an 18"x18" baffle with 2" wings. It sounds really good. I just link to tinker and build. It is a horrible curse!!
The other question is ...how would the Karlsonator work with a Mark Audio 10p? I have a pair of these and really like them. I have seen others build a 6" version for other full range speakers. Thanks in advance.
If the A10.3 is anything like the 10p in T/S parameters, I did a sim of the 10.3(or 2 - I can't remember) once and it looks like a 0.47x scale Karlsonator would work. Not the deepest bass at 70Hz -3dB, but pretty sensitive. The top end of the paper cone may be a bit muted vs the alum cone though. This sim was from Dec 2016. You might be able to find in this thread by looking at date.
Another set of 0.53x Karlsonators for dual 3FE25-16 under construction. These will be finished in espresso brown stain on the outside with natural blonde satin finish on aperture and black Duratex on inside aperture front chamber.
Are those built off of the muddjester plans from earlier in the thread, or new dimensions? I'm getting back into woodworking and may try to build a set to transfer over the 3FE25 duals I did, the foam is looking a little rough from being moved every now and then.
- Full Range
- Mini Karlsonator (0.53X) with Dual TC9FDs
