The SLB (Smooth Like Butter) Active Rect/CRC/Cap Mx Class A Power Supply GB
I have often wondered what such psu could bring to class A/B. there are some hints on Eliott projects page but it stays generic. What would you advice if used foi A/B? Is it a waste of resources?
The Akitika GT102 is a class AB chipamp. It's got a regulated power supply, which is equivalent to the highest possible performance capacitance multiplier (you can imagine it as a Mx with Cap=infinity). This drops an even larger number of volts than a capacitance multiplier, but the result is ultra low impedance, super clean supply.
How does it sound? Fantastic. What does it cost? More than a Cap Mx. Photo below. Notice that the voltage regulator PCB is bigger than an amp channel PCB, and the voltage regulator heatsink is bigger than a (class AB) amp channel heatsink.
_
I've watched this thread hoping to find a candidate for a discrete power-pcb/tranfo build to move between Class A projects while building and testing. SLB is the one to start with! Wow and Thanks to X, Hugh and jhofland! I think more about using a refined modular power supply component approach to simplify build layout and to reduce amp chassis size (not sink size) and make a long, narrow footprint. Makes it easy to A/B compare different PSUs.
Roundtoit - 2 SLB boards - 2 SLB-SR boards
Watch out MOFO!
(Hot, elegant, and delivery on difficult details; These are qualities of items to keep close to home...🙂
I would do the dual mono lock personally. The stereo separation and imaging is better. Plus the ground loops possibility is reduced. I will add you to list when I get a chance.
Both will get you circa 24v after the SLB.
Thanks x -
I'll do the single SLB and do stereo in the 4U chassis. Dual monoblocks would be cool, but there's going to be some belt tightening going on around here soon (no, really) and I don't want to invest in another chassis. - Pat
GB Status Update:
baswamin - 2 boards - Paid
meanie - 2 boards - Paid
jwjarch - 2 boards - Paid
gary s - 2 boards - Paid
nautibuoy - 2 boards - Paid
antoniopf1972 - 2 boards - Paid
ravid - 2 boards - Paid, Simple PSU Paid, ship at same time
Gricko - 2 boards - Paid
poseidonsvoice - 2 boards - Paid
Bkdog - 2 boards - Paid
Jazzfan - 4 boards - *invoice sent*
yoaudio - 2 boards - Paid
van of monks - 2 boards - invoice sent
Wtl - 4 boards - Paid
cerole - 2 boards - Paid
s610adam - 4 boards - Paid
pbergstrom - 2 boards - *need PayPal address*
ferret - 2 boards - Invoice sent
Jimk04 - 2 SLB boards, 2 SLB-SR boards - invoice sent
Roundtoit - 2 SLB boards, 2 SLB-SR boards - Invoice sent
Tubesguy - 1 SLB board - Invoice sent
This is really an exciting PSU design. Can’t wait to try it out. Thanks Jhofland, X and Hugh!
I know it was discussed early in the thread that too much capacitance in the bulk caps may not be a good thing. Is 15mF the limit here? I have a stash of 22mF caps I’d like to use.
van of monks - 2 boards - *need PayPal address*
Roundtoit - 2 SLB boards, 2 SLB-SR boards - Need PayPal address
Tubesguy - 1 SLB board - need PayPal address
nautibuoy - 2 SLB-SR boards - Awaiting invoice (dual rail boards already paid for)
Some close up photos of the SLB verification build (v1). Note that the production v2 will be a bit longer to accommodate extra output FASTOn spade connectors for use as a stereo PSU.
attachment.php
With output slave BJT's (2SA1943N and 2SC5200N) mounted on a cheap $5 aluminum heatsink. The chassis floor plate or the actual side finned hetasink of an amp enclosure will be fine. I love the AMP quick disconnect cables (I use 18ga silicone super soft and flexible wire from RC model cars) - it makes removing the PSU board literally a snap. You also have the choice of mounting the transistors directly to the board in an underhung fashion:
attachment.php
Another view:
attachment.php
End view of the Cap Mx part with the CFP master on the small local heatsinks and the NTC and 22nF ground loop breaker for connection to chassis GND and mains earth GND:
attachment.php
Closeup of the LT4320 active bridge and MOSFETs:
attachment.php
Input AC snubbers are also provided.
GB Status Update:
nautibuoy - 2 SLB boards - 2 SLB-SR boards - both Paid, ship together
Jazzfan - 4 boards - *Invoice sent*
van of monks - 2 boards - *Invoice sent*
ferret - 2 boards - Paid
Tubesguy - 1 SLB board - Paid
Kokanee - 8 boards - Please send PayPal address
Arthur - 10 boards - Please send Paypal address
Mouser has 12,000 of the CDE SLPX 15,000uF 50VDC rated snap in caps in stock for a good price of $5.13 USD each or $4.62 USD each for a qty of 10+. These have a ripple rating of 6.56 amps, and are 35mm dia x 45mm high - Mouser part number is: 598-SLPX153M050H4P3
Hi X,
I am planning to use these boards for a 30W Jean Hiraga class A monoblocks, working at +/- 30V supply. Will it be OK if I add 150 mf capacitor's per rail, after the board? Assume that the capacitors will have an adequate ripple rating, and that I will be using a soft start circuit with a 5 second delay.
Sanjeev
SLB v2 (May 3, 2019) Production Board Top View:
attachment.php
BOM (txt and csv format) and pdf schematic are below.
Hi X,
Sanjeev
You could do that, but since it is a Class A amp that draws a steady current, it would be a waste of caps as I am not sure it would add anything. The whole point of the SLB is to eliminate the need for huge amounts of bulk capacitance. You mean 150 milli Farad right? That's 150,000uF right? It would be a dreadful excess of caps and a waste of money as the SLB gets you 1mVrms ripple with only 30milliFarad (30mF).
Reactions: Mikerodrig27
The purpose was to provide an energy store for improving bass response.
