200W MOSFET CFA amp
Great work guys, certainly bringing's DIY to another level.
The mechanical design is usually a stumbling block for most DIY.
2oz Cu plate on the OPS pwb's?
Happy soldering, good luck on power up test
Cheers
2oz Cu on 200W CFA and PS regulator boards. There are screening masks on high current lines where is possible to solder additional current reinforcements (wire).
One channel 200W balanced inputs + PS regulator
One channel 200W balanced inputs + PS regulator. Example how is possible to mount the bords on the heatsink.
Looks good Richard!
Magnat did a great job.
Still waiting on some good interior shots!
mlloyd1
Here is my DIY packaging of your great SOTA power amplifier design. We had trouble finding blue LED source with consistent and even light output. Think they nailed it now.
Two, two-channel amps are needed for Bi-Amp'ed JBL M2 system.
Chassis is all CNC milled parts.... top, bottom, front, back.
THx-RNMarsh
CFA amp progress
I've just finished one side with 3 amps for my active system. Still missing analog VU-meter. So far sound is fantastic.
This is 200W amp on its way to the finish state. The photos show the bias setting. I used temporary power cabling to have one by one channel out of the box during bias setting and later fix it to the box sides.
Damir
PS. Mario that looks beautiful.
200W CFA -, now VFA, plays
Today I connected 200W amp via balanced inputs to the Benchmark DAC2 and played flac files from my laptop PC.
All is working flawlessly and I am very satisfied with the sound, now expecting results from others who bought the boards.
Damir
Damir
:up:
It should be very good.
My version of CFA using OITPC, although it used very cheap components, but it reproduce the best attack time of music instruments of all amplifiers that I ever heard.
