I'd be interested in 4 boards for either 200W or 100W CFA and 4 boards of PS regulator.
100W CFA 2 boards
100W CFA 2 boards
By the way there two types of PS regulators, BJT and MOSFET, what kind?
OK, the list is here:
ydrozd -----100W CFA 4 boards,-----PS regulator 4 boards
deps--------100W CFA 2 boards
BJT I think... Thanx!
6 boards is to low number to order.🙁
The list:
The list:
Hi Dadod,
How much is the amp board and the PS regulator? I'm interested in getting 2 100W board and 2 PS regulator.
Thanks,
Fred
Thanks,
Fred
Hi Dadod,
Thanks,
Fred
Hi Fred,
If I order 10 100W CFA boards and 10 PS regulator boards the price will be 19 EUR plus shipping per board.
Please, if this is acceptable for you and for others in the list, let me know.
Problem is what I am going to do with the rest of PS regulator boards?
BR Damir
Hi Damir
i'm interested for 2 pcb of 100w CFA and 2 pcb for P.Regulator.After rectification i want to use CRC filter.Can you suggest values for dual mono?
Is sufficient 330va for every transformer?
Andreas
Andreas
Hi Damir
Andreas
Andreas, you can use 4700uF - 0.22R 5W - 22000uF, that is what I use, and yes 330VA is more than sufficient.
Other solution is one transformer of 600VA, CRC and then two PS regulators, almost dual mono. I use that in my amp.
BR Damir
The list:
Andreas B--100W CFA 2 boards,-----PS regulator 2 boards
Now I need acceptance of the price to start PCBs order.
The list:
Still not any confirmation from those who are interested in the boards if the price is acceptable.
Confirmed. Thanx!
Hi Fred,
BR Damir
Ok Damir. Confirmed.
Thanks.
Fred
Thanks.
Fred
The list:
ydrozd -----100W CFA 4 boards,-----PS regulator 4 boards--confirmed
deps--------100W CFA 2 boards--------------------------------
Andreas B--100W CFA 2 boards,-----PS regulator 2 boards--confirmed
fredlock----100W CFA 2 boards------PS regulator 2 boards--confirmed
OK I will order 10 100w CFA boards and 10 PS regulator boards.
Damir
The list:
deps--------100W CFA 2 boards--------------------------------confirmed
The list:
OK I ordered 10 pcs of each so 2 PS regulator boards are still in offer.
Dang, wish I had seen this a week ago. Could use a pair of pcb's
Anyway, I just got a gift from a friend a few days ago. It's a cooling tower with a total of 10 sets of 2SK176/2SJ76 from Hitachi, which was pulled from some pa amp. They are TO-3 types and seem to work ok.
Will your cfa 100w/200w amps work well with these, if the bias circuitry is adapted for these? Also, they won't fit on the current pcb layout, so they must be mounted using some short wires. Will this affect stability?
Dang, wish I had seen this a week ago. Could use a pair of pcb's![]()
Sorry, all amp boards booked, look the list.
I don't know those mosfets and can't find the datasheet, all show plastic version 2SK1761???
Sorry Damir, I made a typo for the p-channel fet. It's 2SK176 and 2SJ56.
I found them here https://www.datasheets360.com and have also attached the datasheets
I can take pictures if you like.
- 200W MOSFET CFA amp
