So long as f doesn't change too much in each timeslice, FFT of each timeslice will report amplitude for integration by summing over a certain bandwidth, and either FFT or HT can deliver the mean f. The bandwidth might need to be carefully chosen or adaptive, but I think each timeslice contains equal energy modified only by rpm which is a restatement of mean f. So I really think all the elements are there...………………
LD
I could try that, the HT might not be necessary with a slow sweep. All the energy would still fall in one bin. In fact there are some nice flat-top weighting functions that might work very well.
Or across a few bins if we choose, according to sample rate. That allows for quite accurate determination of f, as well as amplitude, from one FFT of a timeslice.All the energy would still fall in one bin. In fact there are some nice flat-top weighting functions that might work very well.
LD
Also, there's no reason all timeslices/points in an f sweep need be plotted in the overall result. This might help avoid pop/crackle noise artefacts because noisy timeslices can be discarded based a wideband noise threshold from the same FFT?Or across a few bins if we choose, according to sample rate. That allows for quite accurate determination of f, as well as amplitude, from one FFT of a timeslice.
LD
LD
Yes - rate of change of f sweep so arising will depend on drag, from say, slipping the belt.Dumb question, would this also help with doing relative friction measurements?
Reminds me, I have a late 1950's Lenco transcription table in storage, which has varispeed to 80+ rpm and can disengage the drive...…………
LD
Fresh from the needle the first unfiltered test from the Ortofon record, a square wave.
Looks very nice and clean.
Still working on a 60dB flat amp for the CV sweep.
Hans
Hans
Hans
Is the duty cycle really that far away from 50%?
I ordered one too but am now leaving for the house tonight so I won't get to play with it until next weekend.
It's intentional 7:3 duty cycle 400Hz. I wonder why?Is the duty cycle really that far away from 50%?
Rise times and corners look asymmetric and v soft at first sight........
LD
If I compare an FFT of the 30 Hz to 18 kHz sweep on the Elipson, I can see that the slope is 3 dB/octave up to 10 kHz, then the peaking of the resonant stylus shows up. With the Ortofon, I made an electronic compensation for the RIAA and I can see that the response is not at all the same. It has a rising response from 800 Hz to 2-3 kHz.
If I get time I can make the conversion to linear to compare them side by side.
LD
The only square wave tracks I have are no RIAA, I would think the pre-emphasis would be problematic while applying a square wave directly to the cutter makes sense. This way the acceleration numbers are easy to compute as you have shown.
Hi Thomas,If I compare an FFT of the 30 Hz to 18 kHz sweep on the Elipson, I can see that the slope is 3 dB/octave up to 10 kHz, then the peaking of the resonant stylus shows up. With the Ortofon, I made an electronic compensation for the RIAA and I can see that the response is not at all the same. It has a rising response from 800 Hz to 2-3 kHz.
With the Ortofon you have to play through a straight, non Riaa preamp.
Hans
Hi Thomas,
Hans
Yes. I made however a inverse RIAA electronically in this case.
Tomorrow I will do the same with a straight amp, there is no advice on the record what should be done.It's intentional 7:3 duty cycle 400Hz. I wonder why?
LD
This will of course change the shape considerably.
Hans
That's great that you have one on order.I ordered one too but am now leaving for the house tonight so I won't get to play with it until next weekend.
We can compare results and try to agree on some sort of validated transfer curve.
Hans
That's very strange. Are you sure the correction actually took place ?Yes. I made however a inverse RIAA electronically in this case.
Hans
Hans
Below two pics of before and after correction.
No surprise then. That is meant to be played with flat eq 🙄 Otherwise looks heavily rolled off...…..Tomorrow I will do the same with a straight amp
LD
- Analogue Source
- Cartridge dynamic behaviour
