Cartridge dynamic behaviour
So long as f doesn't change too much in each timeslice, FFT of each timeslice will report amplitude for integration by summing over a certain bandwidth, and either FFT or HT can deliver the mean f. The bandwidth might need to be carefully chosen or adaptive, but I think each timeslice contains equal energy modified only by rpm which is a restatement of mean f. So I really think all the elements are there...………………
LD
I could try that, the HT might not be necessary with a slow sweep. All the energy would still fall in one bin. In fact there are some nice flat-top weighting functions that might work very well.
Or across a few bins if we choose, according to sample rate. That allows for quite accurate determination of f, as well as amplitude, from one FFT of a timeslice.
LD
Also, there's no reason all timeslices/points in an f sweep need be plotted in the overall result. This might help avoid pop/crackle noise artefacts because noisy timeslices can be discarded based a wideband noise threshold from the same FFT?
LD
Fresh from the needle the first unfiltered test from the Ortofon record, a square wave.
Looks very nice and clean.
Still working on a 60dB flat amp for the CV sweep.
Hans
If I compare an FFT of the 30 Hz to 18 kHz sweep on the Elipson, I can see that the slope is 3 dB/octave up to 10 kHz, then the peaking of the resonant stylus shows up. With the Ortofon, I made an electronic compensation for the RIAA and I can see that the response is not at all the same. It has a rising response from 800 Hz to 2-3 kHz.
If I get time I can make the conversion to linear to compare them side by side.
Hi Thomas,
With the Ortofon you have to play through a straight, non Riaa preamp.
Hans
