B1 with Korg Triode
attachment.php
Trimmer pots and power resistors next.
attachment.php
Now stuff all the Q2. Remember the R1 resistors are matched to these particular transistors, do not mix your Q2 and Q1 together!
attachment.php
PCB should look like this now.
attachment.php
With your Q2 installed on the PCB, install the four Q1
attachment.php
attachment.php
Now mount the 10uF capacitors
attachment.php
attachment.php
The NuTube has pins on one side.
attachment.php
Those pins will attach into these holes. This is not particularly sturdy if left by itself, Nelson suggests a small amount of hot glue to hold the device, which will work beautifully. I have a roll of two-sided foam tape and use that to similar effect.
attachment.php
Two-sided foam tape
attachment.php
I cut two small rectangles, place one on the PCB as shown, peel the tape;
attachment.php
Place the second one atop the first,
attachment.php
Align the PINS FIRST in the holes before peeling the tape, then attach the NuTube and solder the pins.
attachment.php
Mount the large can capacitors.
attachment.php
attachment.php
If you have the "V1R0" board, attach jumper as shown. ALL other revisions DO NOT NEED THIS JUMPER
...that's the way Nelson laid this one out. It's a simple enough board that you can figure it out looking at the schematic.
The best of both worlds would be to have the values inside the silk outline and the position name next to it.
Jim,
What is the thickness of the 2 layers of 3M double sided tape you used under the nu Tube?
I have some 3mm thick anti vibration Sorbothane sheet I will use for that position.
Then I will mount the PCB into the enclosure on small M3 (3mm) anti vibration mounts made from very durable rubber - these have a 3mm stud one end and a 3mm thread the other. They are used a lot in drones and remote controlled helicopters.
Once finished I will then stick on some very compliant Acoustic feet - Audio isolation feet for the bottom of the enclosure - these are 30mm dia and around 8mm thick.
Overall with these 3 items this should give maximum isolation for the Nu Tube from external vibration and noise.
Gary - 2-3mm max. Thin enough that the pins stick through the PCB and are easy to solder, but don't need trimming.
Your plan for isolation sounds good. 🙂
Rich - Probably 230 x 170 x 1U. There will be kit options for all the parts. I have NO idea what the timeline will be, you might as well just buy the parts and build it from scratch, it's a very simple layout and you'll love the NuTube. 🙂
I've been using my xmas B1 nutube as a headphone amp as well as a pre....(60 Ohms) HD25-SP IIs. I've made no adjustments to the circuit at this stage for the headphone use.
It sounds quite superb....IMO, so you may not need to look any further for a quality phone amp..🙂. If you were looking for one.
Filament dissipation is no more than 12 mW as per manufacturer's sheet. I would assume power output would be about a third that, if other power tubes are any indication i.e. 4 mW. Output impedance per NP's spec would be 140 ? ohm. So, you need sensitive headphones and high impedance types probably wouldn't work.
I used a headphone adaptor on the outputs when I judged that things were working. One was 30 ohms and sensitive, the other was 80 ohm and very sensitive. I thought they sounded great. To get some current with other headphone types, coupling with Op Amp to make a hybrid would probably be suggested.
cjfrbw - You're not actually listing to the nuTube, but instead the output buffer... 🙂. With it's 392K plate resistor, the NuTube can't even drive cables very well, hence why it needs something between it and the rest of the world. The Jfet buffer adds current (enough, obviously, for some headphones) and doesn't editorialize at all.
"Depending on the Jfets, the buffered output impedance of the preamp is 140 ohms to 170 ohms (including the 100 ohm output resistor)."
I suppose a little high-ish for standard 30 to 100 ohm dynamic headphones.
The ones I used got louder than I wanted with an ipod input (less than 1 V?) so there seems enough power for these types of headphones. I don't know what the impedance mismatch might do for frequency balance etc.
I don't think the NuTube is a power house, but a tech type could weigh in to give more specifics on power output for this particular device.
My Nutube version from the diystore is now up and running and all is well.
I have a question about measuring T7-8 - I have chosen about 9.5V and should be in the “Positive phase range”. What does that mean - do I not have to swap the speaker wires if I want correct please?
What is the expectet lifetime of the Nutube in this circuit?
While in the train, on a back of an enveloppe (sorry for low quality and low brain), I guess another silly idea of mine, but could perhaps the expert give their opinion?
Problem is you want a high quality output cap driving into the power amp, that one has to be as small as possible to reduce cost and help implantation.
On the other hand, as "additional function", I understand perhaps not best but let's assume the B1 Nutube can drive an efficient 600R headphone to reasonable listening level... you want another exit in parallel, which is easy to pick on the board, but you need a much bigger output cap to avoid low frequencies cut off... as this is just a B plan, you could leave with a normal quality electrolytic and a reasonable low Fc.
So as per attachement, what about splitting their ways just before the output cap and having 2 different ways with 2 output caps: low value HQ output cap to drive into the power amp, normal quality higher value to drive into the HP?
Stupid boom paralleling caps... or a possible solution?
Thanks in advance to the experts
Claude
