Slewmaster - CFA vs. VFA "Rumble"
We all have favorite transistors. Mine 2n4403 and 2n4401. Does anyone have experience with MMBT4401/4403. Are the ON dies the same with the same noise and high base spreading resistance. Thanks for the comments. What brand of SMT resin/glue and where can I obtain it? I guess I'll have to buy a 3d microscope. Ray
What you are getting into ...
(below)
Relative size.
I will stay with D-pac - TO-252 - Wikipedia .
And SOT -223 - Small-outline transistor - Wikipedia
SOT23-3 is alright.
, no-363 ... I might have to go SOT23-6 for those cool matched pairs.
no 2mm parts , I'm older , too.
OS
SOT-26, for but there is a SOT-23-6 as well.
SOT-223 is your mid power device.
D-PAK for more power.
All the popular devices 2n440x,390x, are available in the SOT-26. Even Toshiba makes some parts in the SOT-26.
I would think that they are the same dice just in a different package, they say they use die from adjacent parts on the wafer to guarantee match, they are not dual monolythic.
smd IR process requires a specific temperature profile gradient, it is shown in numerous publications.
I have a hot air machine and a couple of irons, no need for expensive equipment unless you are doing volumes.
I recall gmash was using a stencil,paste and his skillet, but he knew the required rates/temp, there is some variation in the profile.
Thanks Pete" So glad to see you back here and still prying into the mysteries of amp design.I hope your trek out west was enjoyable and mindful. Are there any updates to Spooky V1.3 as to parts sub. I built Marshal Leach super-amps in 1976 and wound up replacing almost every part on the board due to his constant tweaking. So much so that I lifted many pads from the board. But things change and all Marshal had was fortran on a mainframe. I'm now building spooky v1.3. It will be the last series of amps I build. I'm not an EE just a music lover. Ray
Greenam V1.2 U1 correct part
hello is this U1 TL072CN the correct one it ends in CN? I just wanna be sure maybe is a typo error I'm not sure also I'm confuse cause pin 1 is output why it said Offset Null 1? 😕
TL072 LOW NOISE J-FET DUAL OP-AMP IC
Vargas
  • A-037.pdf
    A-037.pdf
Vargas
Looks like an error on the data sheet.
It is usually the single op-amps that have the offset null pins.
The datasheet shows the output = pin 1.
Any dual 8 pin dual amp DIP does not have any extra pins for "null".
OS
JLCPCB are gonna sponsor my order they did already
hey guys I was lucky that JLCPCB are gonna sponsor me an order that I did of the Arc welder I have the files for a long time and I always wanna to try the new OPS "I mean few year ago" I know that OS is making a new OPS but I be just happy to have this one this is the same one I just tweaked a few weeks ago to my needs I mean fancy style 😀
Vargas
According to the datasheets, the complementary pair for KSC1845 is KSA992. But in the spooky leach, KSA1015 is used instead of KSA992 is the differential pair.
Is there a specific reason for this?
Sumesh
Since Spooky is cascoded a lower Vceo pair can be used (1015/1815).
992/1845 needs to be used for the cascode since it sees full rail.
For the spooky , any >30v pair can be used , comp. pair only sees 12V.
OS
Vargas
That is NICE !!!
I think it is the best on this forum - by a long shot !
OS
