Open Source Monkey Box
I bet if the slot port was 1/4 up from the bottom the second standing wave at 400-500Hz would clean up considerably. At least if I move the driver position in the hornresp model to 1/4 position the 400-500Hz ouput is attenuated some 20db :) See Strauss monitors for example, seems to have woofer at 1/2 and port at 1/4.
Hold your horses, If I calculated correctly the slot port is currently equal to two 100mm drain pipes, 30cm long. 75mm pipes would be too short and chuffing :)
IF hornresp MLTL model reflects to reality you could add panel between mid and tweeter and make the box ~12cm longer to get the woofer in the middle of the "pipe" and then there shouldn't be any 250hz resonance at the slot port. And you'd get some room for 100mm drain pipes and turn them up from the bottom. Just speculating fhere :D
Can't put a divider between the mid and tweeter, as it collides with the magnet idvthe mid (dashed pink circle).
Also, making the box bigger is not in line with design goals of the Monkey Coffin.
If one adjusts L12 so that the woofer is middle of the "pipe" the 250Hz resonance cancels out and is not showing at the port output anymore. 500Hz resonance is more pronounced here, but maybe easier to filter out by crossover and polyfill. See the other attachment.
Only thing changed between the attachments is the woofer location (L12, L23), huge difference.
Anyway, a lesson here is don't put port at the end of an long enclosure and put woofer in the middle of the baffle to cancel out the lowest standing waves in the enclosure.
I have mentioned this soooo many times.
But your conclusion is not 100% correct, you can indeed put the port on the end of the enclosure, that is not the problem. If the port could be on top of the enclosure the problematic frequencies would also shift.
In general, I find that the woofer should be located between 1/2 to 1/4 baffle length distance away from port. But this will inevitably vary pending on the other measurements of the enclosure, so no fixed rule.
Conclusion: Check and double check every single time, also move port and driver several cm in each direction to verify that there is some slack, should your cuts be a bit off when doing the build. Never hurts to be careful.
Extending the baffle's lower edge does nothing to diffraction, practically. And neither does a small increase in volume to tuning.
Port diameter and length go hand-in-hand. If we use 2 tubes, each must be twice as long as a single tube. Makes it easier to bend them up.
I vote for 2 bent tubes below the woofer and a bit taller cabinet. Still, there will be some resonances in the cab and in port tubes... ¤75mm drain pipe
Those bent tubes in your drawing look like they will be very long. Can you estimate suitable port dimensions that will fit in the existing Monkey Coffin design?
I wrote this the wrong way, it should say 1/2 to 3/4 away from port. So half length and further away.
That would mean.that a port below the woofer is too close. I guess the only solution within the limits of the current Monkey Coffin design would be to put the port in the upper half of the box then. Front baffle is out, so: rear, top, or side of enclosure?
^Try this. Still, that is estimation. A tube will always have standing waves too.
Volume Calculator For Closed Loudspeaker
Port tuning should be tested in the final box with all bracing and drivers conencted. If length allow, it would be easy to change the straight part after the 90¤ bend.
We already know the port tuning. My question was "how can we fit a bent tube port (or two) into the Monkey Coffin?" The way I see it is that the geometricak constaints will be a problem. Either the bent ports are too shorting bend around the woofer and upwards, or their diameter gets too big. If someone finde a solution, please show us a drawing that is to scale.
Apart from that I dont think it will be possible to implement KaffiManns rule of a woofer/port distance larger than 1/2 of the longest enclosure dimension using bent tubes below the port.
Correct.
I have done some experiments with ports on all possible sides of enclosures, front ports are just better.
I had an idea that ports on the sides and top would be brilliant, they are not.
Same with rear ports. It seems impressive until you start listening for minor details in phase and the way the sound behaves between reflective surfaces.
Front ports are just better, particularly if they are a bit away from the floor/ceiling = lesson learned after a lot of time and wasted building material.
No directivity in bass?
Allright, maybe you can say that based on SPL alone looking at a SPL meter, but if you start looking at what the signals (original vs reflections) actually are, how they relate to each other, and how you perceive them.
Then there most definitely is directivity in bass.
You're more than welcome to either verify or disapprove this. But it really is quite simple, no magic involved.
Cheapest and easiest way would be to just make a box with a woofer, port on front, for a "subwoofer" or what you want to call it.
Xo at let's say between 120- 200hz if it behaves nicely a bit further than that, then move the box in various locations in your room. Try aiming the woofer+port into corners, at the ceiling, behind a couch etc.
Then try putting it on a shelf next to the speakers firing back at the wall, firing up at the ceiling, then directly at you in listening position.
Between each and every placement, be sure to walk around in the room, listen to music extensively, try to hear the difference in sound quality, if it's "muddy" or "thin" or "tight" in the various locations/directions all around the room.
See which you prefer.
I did it the hard way, it was more expensive, and involved more sawdust and time.
My conclusion: What some may call "tight" bass, might relate to less phase variations, and is usually the most direct sound from the speaker.
*Flamesuit on*
Kaffiman,
I think you are mixing up a) directivity in bass and b) the fact that the port forms a second source. Bass below say 100 Hz is certainly omni.
The problem with ported enclosures, as I see it, is twofold: firstly there are 2 physically separated sources, that are partially out of phase, and then there are the pipe/port resonances, which often in level are several dB above the speaker passband level at anywhere between 300 and 1000 Hz.
I do not think one can generalize about port placement, although my personal preference is to have them at the back, attenuating the port resonance peaks. YMMV.
Actually, a ported enclosure that reaches into the realm of the 20-30 Hz band is somewhat of contradiction, because optimal in-room placement of the entire system is often at odds with proper in-room placement of the bass driver. See the attempts of AR with the AR9 or the Roy Allison designs.
Brett, it is my claim, and it is the way I see it. I do not have the measuring equipment and/or time to back it up. Might be possible to get something tiny but useful out of the umik though, but I my surrounding environment is not suited for this kind of testing. Small kids, no time at all.
In fact, I just decided to kick hundreds of $ away in DIY parts because I just do not have the time, went and ordered new amps and signal processing off the shelf, feels like a lost battle...
Boden, I understand your view, and it is indeed the established opinion that the sound of bass under 80hz is omnidirectional, and I do agree it is hard (impossible) to localize if you put the sub in a location away from the main speakers. But it doesn't sound good, it sounds like those young peoples cars with no concept of tuning their new and expensive aftermarket car stereo. It's not in sync with the rest of the sound.
Last time I went to the parents of my wife's sisters husband, I asked the man of the house if there was some kids next door with a big sub tuned to death. He proudly proclaimed it was the small 10" closed sub in the corner making all the ruckus. I could not tell if it was random noise from a neighbouring house or a badly tuned sub behind a couch in the same room connected to the tv!
My first clue was when I built the 320liter TH, I just could not for the life of me, make it sound like it was part of the system, it was impressive, gave a lot of "wow" moments. But I just had this feeling something was "off", comparing it to something like a live drum kit after I went to a concert with no extra sound reinforcement I started hunting for the same "feel".
Like I said, I've had ports on all sides of enclosures. And after eventually getting the port to the front, and off the floor, for me, there is no going back.
KaffiMann, I have no doubts about your observations. However I dont think your interpretation in terms of bass directivity is correct. It is well established physics that (low) bass from a point source is omnidirectional. Maybe your observations are related to group delay (as discussed much earlier in this thread)?
