A resistor as a load, for example those 8R 100W that being sold in ebay?
I've read about the benefits of placing the supercapacitor, I am considering the purchase. Of course, I will need some help on how to place them on board since i see in pictures that, but it's not something to examine at this moment.
to get close to this amplifier you need to have very clear ideas and know which speakers to match it with
With the single pair, which is then the native scheme, it has obvious limits in the low range, articulation and dynamics of the medium-low, but medium and high and voices are very interesting.
You want to work around, which would then no longer be a 108 and not even a clone of 108, you can get very interesting results
Connection to the Diodes in front? Anybody knows it is a bit confusion .I connected from amps + to Diodes+ and from gnd to Diodes - and no light at all. Used 47kohm in series and there is 12.2 v for the 12 v entry on the Diodes PCB. View attachment 736014
found that the inputs have to be shorted and there should be only multimeter connected to the output in order to measure the dc offset. On the other hand, I've read that NHB108 should not be operated without speakers connected or else the output will be fried ( this is due to the absence of the zobel network if I'm correct? ).
Shorting or not the inputs has no effect on the offset as there is an input coupling cap. I prefer adjusting with a dummy load at output, but do not think the absence of a load can in any way affect the health of the amp. The original does indeed blow the fuses when powered without a load but this is due to the activation of the crowbar protection. When no load is connected the power on spike at output is sufficient the trigger the protection which blows the fuses.
Anyway, none of this has any relevance to audible noise.
Sound is great. PS Audio Transport and Dac Direct Stream.
I will try to take all of my components out of the power outlet to check if there is a link in the chain that causes that noise. As for a dummy load, what would you suggest ( to be in the safe side, just in case )?
I can see the light in the Diodes now in the evening.Connection to the Diodes in front? Anybody knows it is a bit confusion .I connected from amps + to Diodes+ and from gnd to Diodes - and no light at all. Used 47kohm in series and there is 12.2 v for the 12 v entry on the Diodes PCB. View attachment 736014
If you are trying to light an led with 12 volts, I think that 47K resistor is too much.
Is there noise when nothing is connected and the input is shorted?
For dc adjustment power rating is not critical at all. Whatever you have, 3W is just fine. The worst that can happen is a blown resistor.
Otoh, it is not a bad idea to invest into high power, heatsinkable resistors, so you can test AC performance, max power, clipping behaviour, etc. I have a bunch of 50W 22R resistors and a toggle switch can select parallel and series/parallel combinations using 5 resistors. I think i get around 4ohms and 7.4ohms as test loads.
By at least a factor of 10. Where is that Ohm's law when you need it? 🙂
This noise is too low, I have to get really close to my speakers in order to hear it, but it wasn't present about a month ago. I will check for bad connections and possible interference from neighboring devices. And since it's no harm to do so, I will also check the dc settings, just to be sure that everything flows well.
As for shorting the inputs, also about a month ago I've accidentaly pulled an interconnect from my preamplifier and when I powered the power amp it produced a noise in speakers like a short. I turned off everything, checked the cables, found the mistake, fixed it and it worked fine. But this makes me double think the possibility of shorting the inputs while the amplifier is connected to my speakers.
No I take from the amplifiers 46 VDC supply. But still I think the 47 kohm is to much. Depends on the Quality off the LEDs.
Well, is it here..??
LED Resistor Calculator
You can not use that calculator. Modern LEDs is so much efficient then earlier.
never connect it to the speakers, but test it with the load (which may not be the speakers)
verify the offset with multimeter, cold and then hot.
use a multiturn trimmer
verify it within a few hours
The 22 mf capacitor to ground serves to control the output offset
avoid the servo circuit
in my opinion
I made a clone but with 4 pairs of finals
4 pairs? My interest is piqued.
Is it for higher power, 1 ohm loads or class A? What voltage rails do you have?
Yes, 4 pairs, but we can not talk about Dartzeel anymore
substituted Q 9, 10, 90 and 100 from MJE in to 220 with power transistors the same as the final, the polarizations for the 4 pairs, R 19 and 20 and Z 1 and 2 have been changed
changed C 15, 16, 17, 18
0.22 ohm resistors on emitter power end transistors
Powered input and driver with VCC stabilized at 60 VDC
Powered final stages of power with VCC stabilized at 50 VDC
Replaced C 6 and C 7 with higher quality cap
Bel finale, but another final, a result of stature
Nice! what voltage swings are you getting into 8 ohms at the output?
- Dartzeel amp schematic - build this?
