http://www.linearsystems.com/lsdata/files/BA2018-R1_Wayne.ppt
Here’s the PowerPoint with all the device details.
No in the 2018 line stage. Can't LSK parts be used alternatively?
At ~4:08 in the video, Wayne certainly indicates that it's fine. The SMT part is in the big houses, so I think it's why he drew it around them.
Thanks! Back to my question. Has anyone tried and compared? I'm wondering if there's a noticable difference in this application?
I use what Jim gave me, 2sk209.No in the 2018 line stage. Can't LSK parts be used alternatively?
No.
EDIT: I see Wayne answered at the same time. Both of mine have had random K209 off the reel, they work beautifully.
Do the JFEts need to be matched?
See post #132. You can easily check them yourself.
BDP
You need the K170s, and yes, there is.
Hmm. Seems like we should make use of them. Other than being SMT, why aren't people using these given shortages of regular k170/j74 pieces?
Forgive the off topic, but I'm surprised!
Russellc
If one were to stack two circuits for balanced operation.....
Could it effectively convert Bal to SE, or visa versa?
If so, would you have to ground the balanced negative on the SE side?
I watched the Utube presentation of the BA 2018 Line stage.
I learned a lot going through the presentation and schematic.
My question is application related. What was the BA 2018 designed to drive?
I am guessing F4 / MOFO type circuits.
It wasn't really designed to drive anything in particular more of just a experiment. It will drive quite a few things though especially with the bigger outputs.
Wayne, if one were to use the bigger output transistors, what other components would need to be changed and what would be their new values?
Thanks in advance.
Thanks in advance.
- Wayne's BA 2018 linestage
