Wow - looks nice 🙂 can you provide some link where we can buy it ? In my opinion all that chinese wima, nichicon etc capacitors & op-amps might be fake ...
Is this link permited:
AIYIMA Professional Mini Amplificador Audio Amplifiers Board TPA3116 2.0 Dual Chip Digital Power Amplifier 100W For Home Theater
Feedback -- zero - no feedbacks at all 🙂
Hello all
I just found a new version off my TPA3116 dual mono amp. This one should be equipped with wima capacitors. Looks good.
you mean this?
Yuan Jing Audio - Mini TPA3116 2.0 Amplifier (Weimar Edition) - USD $31.30 - Finished Units
@ Snip3r I mena only the amplifier Board. No housing or others
Is it actually any better than other cheap tpa3116 ? I am worried that all that capacitors might be fake anyway 🙂 This board is PBTL right ? So probably more suitable for 4 ohms load, right ?
Probabely fake but you have the right foodprint so you can tweak it easy :-D yes PBTL.
For such power the power on/off volume potentiometer is a bit too underpower 🙄
The board looks nice... But I'm wondering why the seller state 5Amps instead of higher? If it's to deliver 200W total, at 24V the board should consume more current is it not?
If you listen sinusoidal signal with frequencies 50-100Hz - yes, then you need 200*1.1=220W minimum continuous power supply, or 24V/9.2A PSU.
For music 5A will be enough, for normal listening.
And the board really looks very nice - at least very comfortable for modifications.
If anyone's interested in this?
https://www.diyaudio.com/forums/swa...w-50w-stereo-class-amplifier.html#post5696469
You already posted one by your self
here :
https://www.diyaudio.com/forums/cla...5-bluetooth-4-0-noise-fix-13.html#post5242647
What does this Differentiall-2-Singe-Ended mean? Is it important or should it be removed?
Has anyone tried this to remove noise?
Has anyone tried this mod to remove noise?
Your link is incomplete.
remove most of the noise by from the tpa3116d2 just removing r38. Thanks doctormord !! Are there any good/noticeable benefits with continuing with your recommendations.
*removing R28
I have noticed that 33uH coil are not recomended for 4Ohm speaker.
Thats why I will try this little amp. It has 10uH coil and would replace a dual TPA3116 amp.
2x50W TPA3116 Amplifier
If it is good i will put it in my party amplifier.
Other question, I had the 2.1 TPA3116 amplifier.
I have it in my party amp. This amp was not used for a while... winter and so.
After turn it on it was not working properly. Only at some descend level. If I put the volume up the sound stops and goes.... But after a moment the amp sound normally again. So we were able to listen music at max level for 5 hours and my 18V9Ah battery was able to reload 6Ah. So only 66% where used :-D
The setup is of my party sound system is 4 TPA3116.
60 Euro - probably not worth that amount of money ;-)If anyone's interested in this?
- Class D
- TPA3116D2 Amp
