As T increases, distortion decreases, but keeping the horn end dimensions and length the same, so does the cutoff frequency
To make matters worse, for a fixed Eg, the sound intensity at the horn throat also varies with T, further affecting the calculated distortion figures 🙂.
So you mean it's complicated to calculate! 😉
Regarding Multi-Entry Horn Wizard...
When doing an ME design the ND record created by the wizard is for the high-frequency driver. In this record am I supposed to enter parameters for the HF driver? If so, which parameters should I enter? HF drivers don't have many parameters and I couldn't find any examples for using the wizard. Just need some direction.
It's not that difficult to calculate, but it is another variable that affects the distortion result at a given frequency, along with the values of T and fc.
Hi johnnyjo,
If you don't know the actual parameter values for your HF driver, then use the ones given in the multiple entry horn Nd record created by the Input Wizard.
Sd = 20.00
Bl = 8.00
Cms = 1.60E-04
Rms = 3.00
Mmd = 2.00
Le = 0.05
Re = 6.00
Nd = 1
Vrc = 1.00
Lrc = 8.00
Fr = 40000.00
Tal = 4.00
Vtc = 10.00
Atc = 20.00
Kind regards,
David
The manufacturer doesn't give any specs on the driver. That's why I'm asking. I'm trying to sim a BMS 4594 coax.
Specification
Specification
The limit as T->1 is 1. It is also valid for T>1, where both the numerator and denominator are complex, but the result is real.
...as shown in the attached chart, which plots Bjørn's Hypex correction factor Dh from T = 0 to T = 15.
I am yet to find a compression driver manufacturer that does. They are all very secretive about such things, for some reason 🙂.
^^I am yet to find a compression driver manufacturer that does. They are all very secretive about such things, for some reason 🙂.
Modelling compression drivers
I think there are several reasons. While a lumped parameter model may be used early in the design process, most of the design is done using FEA. In many cases a driver is a modification of a previous model. It is possible to fit a lumped model to an FEA model, but it is extra work that may not pay off in more sales.
When the diaphragm starts to break up, a lumped model can be quite misleading, and show too little HF output compared to the real driver. There are also extra cavities and channels that require a more complex lumped model than the standard woofer model. A simple lumped model will only be a rough approximation, more so than is the case with a woofer.
But the main reasons are probably two things: too few (large) customers ask for it, and there is no readily available method to measure the lumped parameters of a compression driver, in the way you can do it for a cone driver.
Sounds like a paper for a talented guy to research and write!
Multisegment Estimator
I am modeling an single segment exponential horn. Can find the menu for conversion of single segment horn into multiple segment horn.
Anyone?
Anyone?
Please can I ask if there is a new way to accurately model a "Ripole" open baffle woofer in Hornresp? If so please attach the Hornresp file.
Specify your single-segment exponential (Exp) horn as an equivalent hyperbolic-exponential (Hyp) horn with T = 1, then use the Hypex Approximator tool.
Another one for AkAbak... 🙂.
Index for Earlier Posts about Hornresp - Vol I
I am new to the site and started reading at post #01 in this long thread. I started noticing a treasure trove of information from many of the posters here, and decided to try and help to identify those jewels below. This is the first installment of an index file. A short description is followed by a link to the exact post.
__________________________________________________________
Too risky to run multiple copies of Hornresp
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-7.html#post1489465
JBL 375 TS specs
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-7.html#post1489918
Compression driver loading
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-8.html#post1522479
How many lines of code in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-10.html#post1532647
What programming language was HR written in?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-11.html#post1533803
Where is the HR tutorial located?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-11.html#post1533809
JBL2441 TS specs
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-12.html#post1536087
Process to enter driver TS parameters
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-13.html#post1539265
Creation of HornrespMerge program
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-14.html#post1546713
Tapped horn accelerometer verification of HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-15.html#post1591527
Hornresp is now 32 bit
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-21.html#post1629859
HR is now written in Visual Basic 6
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-21.html#post1630965
What is David McBean's background?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-29.html#post1662269
How does HR calculate SPL?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-29.html#post1665063
HR can now be installed on any drive
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-41.html#post1742380
Directivity polar maps are now available
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-45.html#post1794885
Required Thiele-Small parameters
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-46.html#post1796003
How is the driver diaphragm modelled?
HR can now calculate impulse response
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-47.html#post1811561
HR can calculate impulse response
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-49.html#post1817926
Speaker phase discussion
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-71.html#post1876829
Short cuts to navigating through HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-74.html#post1932842
Use of ESC key in HR
Location of the HR Merge utility
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-80.html#post1955564
Inputting data in Imperial format
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-86.html#post2011353
Imperial to Metric conversions
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-86.html#post2030812
New home for HR Merge program
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-101.html#post2104184
Discussion about HR classical horn theory
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-110.html#post2175140
Finite and infinite mouth size and calculated SPL response
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-111.html#post2177459
Discussion about Don Keele's 1973 AES paper and modelling horn mouth size with HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-112.html#post2178704
Number of lines of code in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-113.html#post2180865
Use of the Tab key, Shift+Tab keys, and Enter key
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-118.html#post2195079
HR works differently when using the IDE versus the compiled code. I have run into Visual Basic quirks myself in these two environments
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-119.html#post2198807
New version of HR Merge
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-121.html#post2205845
Where does the directivity tool work in HR?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-132.html#post2257195
Where is the HR download hosted from?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-133.html#post2258328
How to select a different graph range?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-138.html#post2276164
Le Cleach horn flares can be simulated with HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-142.html#post2291022
Working with the SPL chart
Hornresp
Modelling inductance with HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-167.html#post2467949
Modelling a horn without TS parameters
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-171.html#post2477093
Considerations when modelling square or round horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-172.html#post2479870
When to use Height, Width and Width Flare parameters in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-176.html#post2508762
Modelling round and square horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-177.html#post2509887
The effect of wavelength on mouth-coupling
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-179.html#post2524268
The relation of Mmd to Mms
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-183.html#post2529980
A source that discusses TS parameters
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-184.html#post2531575
Horn impedance of any horn depends on shape and length
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-188.html#post2562344
How is a radial horn defined?
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-189.html#post2576826
Modelling a horn without a driver
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-190.html#post2580914
Modelling radial horns with HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-196.html#post2592712
HR takes into account the suspension compliance and resistance
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-196.html#post2600576
Differences between HR and WinIsd
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-202.html#post2643937
Air velocity is now calculated with HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-203.html#post2651589
Acoustic air pressure distortion in horn speakers
HR now calculates system efficiency, air velocity, and air pressure
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-206.html#post2656263
How to run more than one copy of HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-206.html#post2657703
The relation between particle velocity and pressure
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-207.html#post2658354
The use of acoustic impedance and electrical impedance
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-211.html#post2672210
How to export HR design info
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-212.html#post2672903
Comparison between Tractrix and exponential horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-213.html#post2673347
Using resistance and reactance to design horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-215.html#post2674611
A simple explanation for truncated horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-223.html#post2692702
An acoustic horn paper by Bjorn Kolbrek and paper location
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-223.html#post2694920
Discussion of finite horns and relevant mouth size
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-223.html#post2694984
Further discussion on horn mouth size
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-224.html#post2695889
HR assumes no gap between horn mouth and reflective surface
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-231.html#post2749679
The folding of speech horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-233.html#post2750373
Use a spheroidal waveguide for constant directivity
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-235.html#post2760133
When to leave driver Vrc/Lrc blank in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-236.html#post2760663
Use of the Loudspeaker Wizard in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-237.html#post2762539
Modelling a Le Cleach horn with HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-239.html#post2766956
Using impulse response WAV files in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-240.html#post2768669
Time aligning speakers using DSP
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-243.html#post2775113
New mouth size limit for Le Cleach horns in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-245.html#post2779691
Use of the F5 key in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-248.html#post2825437
Modelling two drivers in a horn mouth
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-254.html#post2881110
Modelling an isobaric driver array in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-254.html#post2893866
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-257.html#post2896866
Comparing system volumes in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-267.html#post3027792
Finding the value of Rms in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-271.html#post3057799
The effect of throat compression ratio
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-273.html#post3062243
Throat size and wavelength
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-274.html#post3063256
Using an existing driver
Small SPL differences between spherical wave or Tractrix horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-276.html#post3104914
One way to organize HR modelling projects
Using the memory function in HR
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-277.html#post3131020
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-277.html#post3131029
Using the Filter function with the Find tool
One way to get a cabinet size smaller
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-285.html#post3187545
Number of conical elements when modelling exponential horns
https://www.diyaudio.com/forums/subwoofers/119854-hornresp-288.html#post3189489
Hope it helps, Jim.
JBL 375 TS specs
JBL2441 TS specs
Hornresp
Hope it helps, Jim.
Got it. Thanks.
Hi Jim,
You have been busy!
Many thanks for doing this - it is a great resource.
Kind regards,
David
Hi freddi,
Many thanks for this excellent feedback! You are not "being an idiot" - far from it 🙂. Hornresp simply should not do such things under any circumstances - there is something wrong somewhere.
It seems that you have identified two issues; firstly, that the diaphragm displacement is not what we would expect to see from a DBR system, and secondly, that it is possible to crash the wizard as you have shown. I have tried to replicate the problem you experienced, but so far without success. Would it be possible to provide details of the sequence of events that leads to the blank input drop-down list box being displayed? If I can generate the problem myself, then with a bit of luck I should be able to track down the cause and fix things.
Thanks and kind regards,
David
Further to my message above...
Try as I might, I still have not been able to replicate the problem experienced by freddi. On examining the relevant source code carefully, I cannot see how it could possibly crash the Wizard in the way shown. In the absence of any further feedback I suspect that freddi may have experience a momentary glitch with his computer that did not allow the Hornresp screen to refresh as it should.
With regard to the diaphragm displacement issue, I have now checked that the result produced by the Wizard (see Attachment 1) is indeed valid, by comparing it to the one produced when the same double bass reflex system is specified independently of the Wizard (see Attachments 2 and 3). A completely different model is used in this case, but the displacement results remain the same, as anticipated.
At this stage, I intend taking no further action on either matter, unless of course someone can provide me with a sequence of events that generates the problems experienced by freddi.
- Subwoofers
- Hornresp
