Build This MoFo!
What will I need to drive the MoFo properly?
you will have to answer two questions to yourself:
"How many volts input into Mofo do i need to get the listening volume i like out of my speakers"
"What kind of distortion would i like to add to the Mofo sound (which is rather neutral..)"
Myself i use the following 4
BA3
LuminAria
NuHybrid (Korg triode with buffer by Pete Millet) in two versions:
without step-up transformer (for high efficiency speakers and low volume)
with step-up transformer
I am building the BA-3 pre because it has a lot of gain. It is made for power amps that has no voltage gain. In the moment I use a preamp which has max. 10 dB of gain. This is fine for MoFo with 94 dB speakers. It is only low level recordings where I am close to the 10 dB the preamp can deliver. If I want to play very loud I may need a bit more than 10 dB but I also build BA-3 because of other qualities…..
This issue has been discussed a lot in this thread…...but can't remember the post numbers. I think the purpose was the same......as far as I remember MR also made some experiments with smaller chokes…...maybe he remember where to look back in this thread.
Hi All,
First of all a big thanks to Michael for sharing this great design. I have completed my build of the 24V version of the MoFo and I like the sound very much. Unfortunately, something went wrong this morning. I have built it with a very low priced inductor that claims to be rated at 3.0A (and I am suspecting this is the problem). It has a DCR of 1.3 ohms, so I biased it at a voltage of 3.25, i.e. 2.5A.
Anyway, it has been running for 2 weeks, and this morning while playing some music I heard a pop on the left channel, and after that no more music, leaving a low frequency hum on the speaker. The right channel is still fine. When I touched the surface of the inductor casing, it seems to be much warmer than that of the right channel. I have not started any troubleshooting / measurements yet. My questions:
1. What are the recommended steps to troubleshoot?
2. In case the inductor is found to be faulty, will this be a good replacement? https://my.element14.com/hammond/195s4/choke-70mh-15-chassis/dp/2893269?st=hammond inductor
Thanks & Best regards
Liu
Hi Zen Mod,
Thanks for the reply. I have done the following:
1. On the faulty channel, measured the voltage across the inductor, V=9.5-11.0 increases with time, does not change much when I turn P1 anti-clockwise (many turns). Iq=6.9-8.5 A.
2. On the good channel, measured the voltage across the inductor, V=3.25, Iq= 2.5A
3. Swap the inductor or the normal channel to the faulty channel, V=9.5-11.0, same as step 1.
So I can now conclude that the problem does not seem to be caused by the inductor. So how should I proceed? Attached are pics of the finished chasis and the faulty channel mounted to the heatsink. Visually I can't detect any burnt component. The colour of the solder on the transistor does appear slightly charred as compared to the normal channel though. Could I have burnt the transistor?
Best regards
Liu
left down - button "post reply"
or left right , button "quote"
in both cases you'll have opened advanced reply window and if you scroll down , you'll see "manage attachments"
it seems you have Dodo mosfet , and it's easy to check that , but only when you are able to post pictures
OK. Another go at attaching the pics.
