50w Single-Ended BAF2015 Schade Enabled
Big YES for the Jensen's quality 🙂
My as well is point to point soldering made amp.
Next step is to try all technology
: carbon, mox, metal film, wire wound, bulk foil, etc.
rolling of 220R 3 Watt's feedback resistors, 22R at the drain and
if I get another input transformer just for the pleasure to hear the difference in acoustic instruments tone fidelity.
BTW IXYS price go up
If I were to lower the voltage of the circuit from 60v to 40v, would the drain of the mosfet be at half the circuit voltage, e.i., 18v-20v?
Is this similar to the ACA bias adjustment? Would I then monitor the drain voltage while adjusting the bias at the gate, arriving at around ~20v?
Thanks,
Vince
Big YES is perfect for the IXYS bias inside the Schade 50W 🙂
Multiturns trimmer for voltage precision.
Zen Mod version if made with other resistors values.
Schematic courtesy of Mighty Pumpkin :Pumpkin:
Good question. Will be using a IRFP250. I believe it's based on how much voltage will appear at mosfet drain, which is around 18-20v, depending on symmetrical clipping. Not sure what the figure will be. Will have to monitor it while adjusting.
I have a prebuilt LM317 circuit to speed up the build process. The transformer has extra 12v and 18v secondaries, so voltage is not a problem.
Cool Vdi_nenna build with H2 , H3 switch on the CCS ?
Between D and C 0.1R resistors connection points.
Me ask swap IXYS to SIT: 2SK180, THF-51 or 2SK182ES.
Mr Pass use 2SK77B any datasheet available to compare with similar Tokin's ?
FAB like experiments but not rare triode sand smoke 😀
