The BA-3 as preamp build guide
I finished building my F5, hooked up the BA-3, and what do you know -- a ground loop (as well as a good bit of gain "whoosh"). F5 is dead silent without a pre connected. Tried another pre on the F5 -- bit of hum with that one too, but less. Tried two sets of shielded interconnects -- no difference. Tested BA-3 with a cheater plug -- ground loop quieter, but still evident.
Here's another picture of my finished BA-3. Even though the F5 seems quiet, should I be inspecting there too? Both amplifiers have safety and signal grounds bolted directly to the chassis at different points. No NTCs or other components in the ground plain, in the event that's helpful.
Everything sounds good otherwise -- I just hate hum!
Thanks — tried different combinations of removing 0 v from chassis. With 0v removed just in the F5, the hum is gone in one channel and significantly lower in the other. Don’t want to pollute this thread since it’s clearly not strictly a BA-3 issue! I’ll double check the signal chain in the channel that’s still humming. Still dead silent with no inputs on the F5.
Appreciate the tips as always!
As I recall, this is a relatively common problem - an earth loop when the preamp is connected. My memory is poor, but I think I recall AndrewT providing a fairly thorough analysis of working through this in the F5 thread, probably a couple of years ago. Good luck!
A few thoughts:
Connecting ground in different places can potentially cause problems. Try connecting them at the very same place. Alternatively, try inserting a CL-60 between PSU/Signal ground and AC Mains Earth point. Sometimes, a little resistance removes a problem. Another thought is to use one of the diodes from a bridge rectifier between PSU ground and Mains Earth. I've had some amps that needed a direct connection in order to prevent hum. Some needed a diode, others needed a CL-60 to remove hum. Experiment with different configurations.
Thanks -- in preparing both my BA-3 and F5 builds, I had overlooked the role of the CL-60 in the grounding scheme. I had mostly focused on the role of the CL-60 as an inrush current limiter in these designs, which I didn't feel I needed for the BA-3 and am using the DIY Audio Store Soft Start Board for in the F5. I hadn't thought through the fact that the design I was implementing would introduce a massive ground loop, mainly because I've never built a pre/power amp combo (the F5 is my first power amp after a half dozen or so preamp/headphone/phono stage builds).
I ordered a bunch of CL-60s today so I will start there -- lifting the BA-3 and/or F-5 grounds. Really appreciate you sharing that it can be a trial and error situation. I'm most concerned that the hum is so much more prevalent in one channel, but we'll see what happens. I'll report back once I'm able to try some options.
Is there a schematic somewhere which includes an e.g. 50k pot/attenuator for vol. control? …...I want to see how it interacts with R1 and R2.....just to be sure. I can probably see it from the way 6L6 wire it in the start of the thread but just to be 100% sure I do it right when time comes…….
pictures
Hallo
I am building BA3FE as an I / V Ad1865 converter with 2sk170V and 2sj74V jfets current 14.5mA input impedance to sources of approximately 10.4 R
mosfety to irf610 irf 9610 with 150mA . I would like to show the scheme but I can not load photos
how to do it , please help
