LX-mini Crossover Article
Here is an example.
On the Analysis Limits page, which you see when you press "RUN",
You add two more lines, like the other two, but with
DB((V(HIGH)+V(LOW)/V(IN)))
DB((V(HIGH)-V(LOW)/V(IN)))
and you will get the summations for + and - phase
My current crossover has op-amp buffers and I have set up impedance balanced outputs by adding a matching resistor on the output ground. I see that this circuit has 100 ohm resistors on the outputs. I wonder if the same thing could be done with these buffers to create a balanced output.
Yes, but you need to add the output impedance of the Jfet to the
value of the 100 ohms. If you know the transconductance of the Jfet, then you can invert it for that value.
Example, 40 mS transconductance gives 1/0.040 = 25 ohms.
Looks like that may be hard to measure. Would your example be useful as an estimate for these Jfets to get in the ballpark? Perhaps it is not worth doing. What do you think?
Thanks for your reply.
If you need to bypass a capacitor, draw a wire around it.
If you just want it gone, give it a zero value.
If you need the resistor to be open, give it a 100 Meg value.
If you need it shorted, give it a zero value.
Feel free to experiment with the sims - copy and paste, change values,
draw wires, add new test points, and so on.
If c15 and c16 are “ gone” how does the signal reach the high out? Please clarify.
Two sets of options: You can bypass a capacitor with a wire or replace it
with a wire if you want signal to continue to go through. When you don't
want signal going through, for example when it is a low pass to ground
filter, you set it at zero or delete it altogether.
Xover finished making music...first impressions
Because I had been using a minidsphd 2x4 set at 100hz at a 12db slope, the same parameters I set in the lx-mini, I haven’t seen the necessity of even changing the volume setting in the Crown amp. powering the “subwoofers”. I have reversed their polarity though, because this was done in the digital domain in the minidsp. Right of the bat, the presentation is fuller sounding and it is more transparent and smoother. The mini was a little “threadbare” in the highs compared to this one. I notice that bass might go deeper. I don’t think there might be too much “break-in” here. The mini is really a bargain and a very good tool to experiment and to set various parameters and really sounds pretty good also. My main speakers are the Spatials M4 powered by a FW F4, ba-3 linestage and a pair of diy Ripole subwoofers. One thing to bring across is that making your main amp reproduce frequencies from a 100 hz up really makes the system sound more “effortless” And thanks Nelson for making this available.
