10F/8424 & RS225-8 FAST / WAW Ref Monitor
Hi X -
Quick question: the woofer zobel is 4.4uF and 470m Ohms? Seems like a huge resistance here. I haven't found much commentary on this zobel and its effectiveness. Also, I have assumed that R4 truly is as shown "intrinsic to L4." There is a much earlier listing of components that indicates an actual Dayton 1 Ohm resistor as R4.
I'm progressing with the 18mm BB cabinets, but I went with earlier external dimensions showing a baffle width of 11.5 in, height 15.75 in. Really different from the 2018 vintage box! Looks kind of fat and short in comparison. Looks better with offset tweeter/widerange.
I've experienced this confusion before in trying extract all the most current info from a very long development thread. Many changes large and small over 1420 posts.
Fun fact - after rejecting the orange safety cone dagger I've come around and ordered some dark red ones. I'm also thinking they'll help by using less baffle area than what I had planned in 1/4 ply.
Cam
From post 1, the dimensions were stated as:
internally 8in wide x 12in deep x 16in tall.
So with 1in thick XPS that would make the baffle 10in wide, not 12in. But I don’t think that’s going to change the XO too much.
I'm kind of kicking myself but also trying to turn it to my advantage. A bit. I doubt anyone else will have this shape for an XRK FAST-variant, so there's that exclusivity factor.
Will post pics when done. I've been wondering at the apparent lack of other folks posting their creations. Yes, I've seen a few in this thread but mostly they deviate considerably in box shape, bass tuning, and even driver selection. Must be the DIY mentality and a use-what-you-got resourcefulness?
Now i know you own relative expensive FAB filter and in past hinted this HF trick before that can help repair power response into room up high for a beaming small fullranger verse a real tweeter. Think we can agree that we sense there needs to be a high shelve filter boost somewhere so that room reflections gets bit brighter and natural for a small fullranger (dull room power response) verse a real tweeter but when we do it down the road it gets tiresome and bit unnatural, think culprit is in phase domain we do the reverse distortion that of a real XO filter in we push timing in HF to be slower and again distort original timing or line up of hamonics relative to ground tone, therefor that high shelve filter boost somewhere needs to be a linear phase boost so that it doesn't change timing of original recording but adds a lift in HF amplitude only (not phase) to repair power response error into room for our midtweet fullranger. Below is my own FAB filter linear phase high shelve filter boost that makes a 10F or TC9 more or less sound natural at my specific room, set it to "Linear phase" and "Max" as highlighted in red inside your player. Recipe is first tune your system and house curve so that when standing within 1-1,5 meter of speaker where direct sound will rule it shall sound like a dream, now go to different listening positions or sweet spot and gently dial in some high shelve filter boost schemes until tonality sounds a bit like standing 1-1,5 meter from speaker system, it probably can't be as good as within 1-1,5 meter but the tonality will guide when its too much or less. From now on remember not listen pure on axis because its bit too hot there but timing is right because we use linear phase amplitude boost without touching time domain, myself have constantly a old ECM8000 mic to hang 10cm in front of 10F so that hot beam is isolated behind it or spread around it if one momentary happen to be positioned on axis.
Hey Byrtt,
I used that trick on my OB with the big TB 8".
The effect of turning on and off the Linear to Max is not subtle!
Without it, there is instruments separation, but the image is a bit blurry.
Turning it on places everything at their place, razor sharp. Also, centered voice was a bit wide spread across the centre, but with the Max on, it is really narrow, pin-point like, right smack in the centre.
Thing is, the latency is horrendous, so it's only valuable for 2 channel listening. If I bring in the HT setup, or even just add the sub, it is way off sync.
Cool thing though.
Thanks for the tip!
how about bringing in the spiral loop as in nautaloss speaker for the full range?
i am sure, it will have to be a pretty small loop length. maybe 12"?
You could put a Nautaloss inside but I find Dagger works fine and is more compact. But maybe leave it outside and add woofer below. Sort of how I used to do the full range driver blind comparison threads.
Thanks the feedback on filter perceval, admit a latency buffer will exist into Max mode its just myself is nut about get better sound and so cost of that little latency is alright for my system, if you down the road subjective look into it again then suggest try run only one mono speaker (could be L/R feeded) and if that scanario also show improment then for mono speaker dial it into best in room sensed natural power response curve and check it from different locations that it stays mostly the same, now turn on stereo and that should really rock then. I could be wrong in that mono suggestion but discovered myself too often dial in some settings that subjective feels stand out for the good and then after a while find out its was a overreaction, where that simpler mono speaker and less variables for ears location relative to a stereo triangle and reflections improve on precision to judge where we really are, for a mono speaker even at close range and on/off axis there is still clues for how is its natural resolution/3D/rhythm of harmonis lineup.
Think in a logic world if a small system latency is okay missing room HF power response amplitude because of beaming should be boosted with amplitude only linear phase boost because material is mastered in a smooth minimum phase enviroment, and knowing a minimum phase amplitude boost will change original timing as is case for some drivers build in amplitude rising response, then scanario to get back original timing is smooth out that build in minimum phase rising response using minimum phase EQ and now lift HF area with linear phase EQ until room power response sounds natural and stay away from being 100% on axis.
Dagger is polyfill or fiberglass as you suggest. Stuff it denser at the vertex and slowly tease it out loose and fluffy towards driver end and leave about 1in space without stuffing. Line the internal walls of the Dagger from the driver end for about 2in with 1/4in felt or melamine foam cleaning pads cut to about 10mm thick. This really helps prevent any back reflections on the driver and gives it a clean sound rivaling an open baffle.
For the larger main box, line at least 3 of the inside walls with egg crate acoustic foam pads, then add fiberglass or polyfill into the nooks and crannies around the Dagger, and in the main volume. I did not weigh it - but a good amount not too dense.
Optionally, line the outside of the Dagger with Noico mass loaded butyl rubber car door panel sound absorber. Also optionally line the inside of the main cabinet with Noico underneath the eggcrate foam. All of these little details will reduce the resonances and vibrations to really clean up the distortion from mechanical vibrations.
Don’t forget to put a round over in the baffle cutouts to allow the drivers to breathe.
Wow! Clarity of an OB without the OB drawbacks. Plus the time alignment. This project has a lot going for it. I'll bet it sounds great. I am especially keen to see how CGodecke's build materializes with the cheaper TC9.
Hi xrk971, what type of adhesive do you use for the egg crate foam and Noico?
I like hot glue for foam. Quick and easy.
Hot melt glue for foam and Noico is self stick. You need to give it a good pressure rub with a blunt tool like a spoon or a roller.
It can sound very good with a TC9. There is a slight difference in subjective sound signature between paper vs fiberglass. Some people prefer paper. TG9FD 8ohm sounds almost like a 10F for 1/5th the price.
What do you guys think of this for a midcone? Found them in the flowerpot section, ideal dimensions and seem to be quite sturdy. Walls are approx. 3.5mm thick
That can work, I would add a thick disc of 1/2in felt at the flat end or use melamine reticulated foam cleaner pads. Ideally it should come to a point but this can work. Don't forget to line the first 2-3in of the mouth with felt or foam. Making a 3 or 5 sided Dagger out of whatever material is also very easy and gives the best result as it avoids the round resonance mode of the cylinder.
