Thank Carl, but will you ship the pots from Tayda with the PCB kit?Yup, that's it minus the Lorlin front panel switch. Mouser stocks them now.
I do not supply the pots. Buying the pots has been left up to the builder.
Is buying those pots a problem for you?
I do not supply the pots. Buying the pots has been left up to the customer.
No I am asking because they were part of the kit in the beginning, I am doing my BOM list right now and i am checking what do i have new to buy (not in my inventory), thanks
Omeg green pots now available in the UK
At last my order of 4k7 pots arrived so can get on with the build
CPC still have 90 in stock.
https://cpc.farnell.com/omeg/pc2g16eco4k7a/pot-dual-gang-lin-4k7/dp/RE04429
look at TMEThanks!
I'm finding several parts, like the aluminum electrolytic capacitors (UES1V101MPM), to be out of stock at mouser and digikey. I found a few on arrow.com, but not all of them and it seems like many are back-ordered until Feb 2019. Looks like I'll be waiting a while.
They dispatch in New Zealand
Thanks HADIHF for the I/O schematic. Very Nice. Needed for troubleshooting. Can anyone take a quick measurement of the output of the 12v reg on their boards and report your voltage? Mine measures 17vout with 19vdc input. I expect the 19 in that is what the power supply is. I checked for orientation and then replaced it but still the same. Everything works okay but it's just bugging me.
BTW build your own cables everything can be purchased from Amazon. Much cheaper in the long run.
Reg output should be 12VDC and input should be 17VDC
Hi Freecrowder - some reports of regulator oscillation in thread #1058 and onwards. This results in the o/p voltage sitting ~2 V below the i/p voltage, which sounds like what you are seeing. Suggested fixes were additional capacitance - one user suggested soldering SMD caps directly on the regulator pins, on the underside of the board.
Just an update. A 22uF tantalum directly across output to common solved the problem. I also notice that both pass transistors on the DC PS run much cooler now. You couldn't hold your fingers on them for more than 5 seconds before.
Hmm ...
I've never experienced this problem. Perhaps some 12v LDO parts are more susceptible to oscillation than others. In any case it is a reasonable thing and I will add a part pad to the IO PCB. Thank you for sharing!
Hmm ...
Never come across this myself either. Must be that particular LDO.
MadInventor,
I was toying with the idea of using a pair of the Amgis #L01-6354 transformers shown here at Digikey:
L01-6354 Amgis, LLC | TE2254-ND | DigiKey
With each of the transformer secondaries wired in parallel to get the needed current.
Incidentally, what part number is the Q2 device??
Anyone have a secondary source for this xformer? Seems DigiKey is either offline, or they have an error on the quantity available. Equivalent Mouser part # ?
redjr
redjr
Mouser isn't a dealer for those transformers. As far as I'm aware Digikey is the only dealer in North America for them. I just bought on from their Canadian website this week and can still order more of them. Maybe there's a glitch in the US site right now?
Thanks. I'll check with the Canadian site.
Here is a graphic rendering of the power supply PCB. It measures 159mm (6.25 inches) x 63.5mm (2.5 inches).
Carl,
Could you point me to the latest BOM for the original project PSU board pictured above? Thx.
redjr
redjr
True, error with chrome browser, I tried internet explorer, no more quantity/price error.
Carl,
redjr
Here you go ... Dropbox - DSelf_PwrSupply.zip
Thanks.Here you go ... Dropbox - DSelf_PwrSupply.zip
I have been listening to this pre off and on now for about a week. I'm comparing to a broskie Aikito with 6sn7's. Was very impressed with the overall sound very smooth on upper frequencies. It does present a problem though in my system which uses some older Maggies. When I use this pre my speakers bottom out in the bass range at a lower volume than my Aikito. It doesn't really sound like the bass extends down any deeper but I'm assuming it must. Even when I turn on the tone controls with bass gain turned all the way down the speakers bottom out sooner. May look at using sub with the maggies.
- Analog Line Level
- Doug Self Preamp from Linear Audio #5
