UCD 25 watts to 1200 watts using 2 mosfets
Hello Guys
Nobody want give or share PCB files for supplier, often same with schematic, people make big secret
Detex Audio Thailand dont sell IRS amplifier Boards to me and friends,
he say, dont sell for foreigner and Thai People have foreigner friends,
crazy this guy !
I get angry this week and design AUD600 PCB by myself !
I accept to share files for PCB supplier and schematics with other DIY
Only manojtm share AUD600 schematic with me....
Have design double Layer PCB for AUD600
- add DC protect Crowbar (thanks to APEX)
- add Led for Power - Signal and Clip (thanks to APEX)
AUD600 PCB IRFP4768 Mosfet with Crowbar and LED Power - Signal - CLIP
AUD600 PCB with 2 x IRFP4768 Mosfets with totem pole driver, Crowbar DC protect and LED Power - Signal - CLIP
In this circuit i get 5.9v dc at out put please help me
Some months ago I did finish a class D amp, a fase shift frequency doubling type, it give very low distortion in sim, with deadtime active, output is 8 amps in 8 ohms full bridge output,.
So with good parts and a very fast integrator, comparator and mosfets class D can be high end.
Do build it in future to see, now first the allfet circlotron, who is a lineair amp.
regards
Two different 900w amplifier operation. Different circuits from each. I have copied the pcb to the other's scheme but I don't have both at the moment. No plugs. No current draw. Integrations are intact. I wonder what could be the problem? The material on the circuit without schema was deleted. I hope the cd4070 is right.
check signel input non inverted and inverted ,,,ok
,,,add 1k 3w for each amp speaker out and gnd0 .
