dear sir plz help me a i assemble it .there is no souund at out put and ic cd4049 becomes hot.thank regards
masood
Good Morning. Do you have the wiring diagram?
I have only pcb upper mask and i also want its schematics. Thanks
Ok, thanks.
hi manoj
plz.help me to built this amplifier as i have assembeled but not working.thanks
hi masood please post the pcb files and photos .
hi manoj
need more details , before treatment
(because this is complex circuit system with 6 different circuits + protection logic)
give you some tips
1.do not apply more than 90V-0-90V (problem of 2n5401 and cd4049)
2.limit the switching frequncy to 120khz(BD139 and BD150 slow)
4.change 100ohms (mosfet bias resistor) to 27ohms (dead time too long)
5.chand that 10W idiot resistors use only 2W 5.6K (90*90/8.2k=0.98W)
6.add 10uf(low ESR) to IR2110 bootstrap (to bias 3 mosfets + 3 100ohms +gate drivers)
.....use 2 pair of mosfets and remove gate transistors connect directly Ir2110 driver drive 2+2 irf4227 easyly ... set switching frquncy 180khz
output inductor 40uh
thanks dearneed more details , before treatment
give you some tips
i will try .thanks
is it safe or advisable to do that really ?? the ir2110 will heat up greatly.
sd1500 class d amp
Dear sir
From where you get this sd1500 PDF.thanks
sd1500 class d amp
thanks khalsa , have you tried the amp with success??
yes sir but semi complete i try to complete soon
hi sir , cool to hear that photos please post sir
sd1500 top
it is here
it is here
it is here
hi sir masood i mean your build photos.
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
