Find my thread.
I give only schematic.
Dear Mr. Kartino
Do you have distributor for assembled PCB from this amp ?
I want buy if possibile
please send me PM if available
new desing 300W+300W Rms true deep bass
+-56V supply voltage
40V peak to peak output voltage @ 2ohms
(28Vrms @ 2ohms /actual 400W)
2xIRS2092 4xIRFS4227
TDA7416 audio prosesor/stm32f103 controller
600w class d irs2092 - YouTube
YouTube
hi
i work with stm32f7 too
i want use tda7317 and 7318 in my design.
please share your tda7416 schematic with me in q1audiopro@gmail.com
do you have advice for me about audio processor ic ?
i like DSP for this type projects.
thank you
hi dear friend
i do not work with PIC and do not have knowledge about this type programable chip.
i work with arm STM32 and STM32F7 more
sorry for this
sorry for this
Hi Sir,
You ca easily interface TDA7419 with arduino(ATMEGA328P)
Hi Hadi,
can you help me to program PIC 16F88 and TDA7419
MANOJ
Hi Sir,
you have lib files
MANOJ
Triell 3200
Hello dear diy and masters. I need help. I made 2 boards triell 3200 (post 2078) and smps xp-5000 (do not use this smps).
I have 4 high-quality power supply - eltek. It's 54v 35a.
I will connect consistently two on left and two on right board. It will turn out +54-0-54v and +54-0-54v.
What do I have to change in boards of amplifiers to use +/-54v, instead of standart 127v?
What elements I need to replace?
Help me please. Thanks, and sorry for my bad english.
you have lib files
MANOJ
Hi dear
my TDA7318 is work fine.
if you have a telegram account give it to me
may be can help you to crate it with ST MICROCONTROLER or AVR
have good time.
My New PCB , IRS-2000D , will be IRS-3000D if used +/-130V 😀 .
how did it go with the 3000d irs? I want to put it together to use it with 8 ohms.
Hello Mr. Kartino. What do I need to change in the circuit to start with a power supply of 65-70 volts?
Only keep the op amp at input stage to be enough voltage supply, no drop.
Dear Mr. Kartino
Sorry that the PCB is not available at this moment.
Hi Hadi,
MANOJ
use mikroC 2009 or 2011
I2C library its really easy
hi
thank you
I dodnt use DSP library,(cubemx,KEIL) stm32f103c8 board to control LCD and I2C audio prosessor and usb mp3 decoder chip(china) easy
Hi Sir,
yes its easy and good,
but the problem is ADC reading speed and LCD responce time
PIC and arduino libraries cannot adjest ADC read time and LCD dealy time.so the spectrum annelyzer not responce smooth
except spectrum all i need (sub(frq adj & Q adj)+bass+mid+treble+balance+fader+input select etc.. LCD with encoder
MANOJ
this is mikroc cord for TDA7318 PIC16f887
rotary encoder+ china remote +LCD module+EEProm memory
https://www.youtube.com/watch?v=RcGN6nR861I
try your own C cord , help with this ,I2C send, bass,trible,volume- calculation,rotary encoder part,IR sensor part,innerupt
MANOJ
Hi
select a stm32 chip
i will write a code for your chip
I2C is a simple protocol for me
you help me before and i am happy for help you
have good time bro
Hello dear. Can we help me in my triell 3200? What resistor i must be replace for +/- 54v supply?
P.s. post #4667.
P.s. post #4667.
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
