Bob Cordell's VinylTrak
PCB finished, ordered, manufactured and 50% soldered.
3D view...
Thank you, Bob
I design PCB for both MC and MM versions (MC version on picture).
Schematic was heavy modified. Only transconductance amp. with HF Eq. the same.
LF Eq, DC-servo, Output Buffers are different.
Now I waiting for PCB for external power supply.
Hello Audio1Man
Thank you for response.
I use BK-HTC-30M. See picture
BK/HTC-30M Eaton | Circuit Protection | DigiKey
It is impossible to accidentally touch side contact with finger when replacing fuse in BK-HTC-30M.
Need at least nail and great desire. There are many others easiest ways for electric shock. 🙂
But thank you for suggestion. I will make thus next time for 101% protection.
-- Best Regards,
Victor
Hi Black Jack
Some fuse holders are much better or safer than others. Some have large metal below the plastic, and when removing a good fuse or replacing the fuse the fingers can touch the metal and the fuse contacts the ring while inserting.
Almost all of my designs have needed UL, CSA, VDE & CE, so I always look for the things for human safety. Many persons can earn the Darwin award.
Again a great job.
Duke
