The BA-3 as preamp build guide
one can always expect help here , be it question about component selection , or little math
I tend to have strong opinion about chip regs (mostly series regs) versus proper shunt regs
no comparison , when shunt reg ........ I mean - entire PSU, inclusive shunt regs - executed properly
ZM... I have seen you make reference to a “proper shunt reg, with proper implementation”...
What would be proper shunt and what entails proper implementation?
I would read the SuperReg article and thread and see if you are up for it.
Super Regulator
You will need a separate cap bank and rectifiers in front of the super reg. The Super Reg board has no cap bank and rectifier diodes on board.
or you could spend $15 on Amazon and have it up and running in no time with lm317/337.
I understand the separate rectifiers ( lol recognize those squares in people posts)... but capacitor bank I don’t think I have seen an example of
Official Court Jester
Joined 2003
generally , I prefer regs with error amplifier ,to ones being set as sort of reference followers
also , I'm heavy biased there ..... during the years , tried most best known , and even if I was satisfied with some of them , wasn't satisfied due to feeling that pure cloning isn't enough
so , back to biased - Shunty and Good Gemini are my cup of tea ; Good Gemini, as later - even if simpler , made with even greater care of phase behavior and pcb routing , which is of same importance as electrical design
if you want simplest possible but with good performance , look at reg in PSM LS article
Received first batch of parts for my build....
From Digikey. Ordered all resistors, mosfets, vr's, etc. The bill of materials specifies all resistors as 1/4w except one, which is 3w. But, these resistors are very very small, compared to what is in the board photos in the threads... are you guys using 1/2w or bigger resistors?
Joined 2007
A lot of people are using Dale/Vishay RN60D resistors which are conservatively rated at 1/4 watt. They are bigger in size and probably good to a 1/2 Watt. That's more than likely what you're seeing in the photo's.
BA3 Preamp
I thought I was almost done but I decided to swap out the Auricaps for a pair of Stealthcaps. They are considerably bigger and I have some space issues but it should be okay to solder the output wires and ground etc from below the board. The pads should be able to take the solder. Has anyone soldered from below the board and are there any issues with doing so? Also the cap wires are about an inch long? Is this going to cause me any problems that anyone can foresee?
Wires to bottom of board is no problem. Cap wires are no problem...you need to be able to measure DC offset before the cap so the length of bare wire is good for that.
