Build This MoFo!
Founder of XSA-Labs
Joined 2012
What about a symmetrical MoFo?
we could use a mid point secondary of a transformer, currents would flow in opposite direction cancelling the flux
so no need of an air gap
a simple E core or toroidal transformer could be sufficient
Something doesn’t sound right? You won’t get any energy storage in this to allow output swing greater than Vcc, which is why it is used.
or
The whole article from John Broskie:
index
I wanted to go this route. But I was advised to use rather big transformers (to get enough inductance and a low resistance). This is also expensive. Plus you will need to adjust the whole system to a nicely balanced current (as written in ZV7). I don't have this equipment.
So in the end I was lazy and bought a Hammond 159ZC. No regrets.
Founder of XSA-Labs
Joined 2012
zeus with only double choke (toroidal double primary) at the output
no transformer at the input, bias and driving à la MoFo
I would go for a transformer and use the double secondaries (lower resistance). I think the Zeus does this too.
And use a transformer at the input and bias a la F6. You can drive it SE or balanced with this.
Of course you don't have a lot of MoFo left......:p
