... And in order for the situation to be more interesting, I decided the speaker would be 2.5 bands
I have an idea to make a new project to in the base there should be two 10" loudspeakers - just an idea. They look like animals, maybe dinosaurs, but important are 20Hz.
And the original model will look like this;
Why two midrange drivers?
I think everything is explained in post # 74, but you may not have come to it.
So, especially for you;
SEAS Excel W26FX001has a sensitivity of 87 dB / 2.83V, m /
2 x W26FX001= 90dB, 1x W18EX001 has -88db, that is, at the one same level of volume amplifier, we will have more bass and we will not have enough environments. For this reason, I even wonder if I cannot change the highs with
T29CF002.
T29CF002.
Shouldn't baffle step compensation require that woofer sensitivity be higher vs mid/tweeter?
http://www.diyaudio.com/forums/mult...vity-versus-woofer-3-1st-post.html#post987350
continue with the collection of the cabinet;
Now I can make the exact measurement of the volume
And that's 31.5l, just as much as I need!
Oh, l forget to show you what I did to get that volume!
I maked a filter compartment (for the MW and TW), the W section will be in the box;
previously make the last layer-10 mm MDF / to get a sandwich construction / on the front panel and the bottom;
Last constructive action ,I will install the last layers of 2 x 4 mm bent MDF.
It's almost a pitty you have to cover the inside, it's a piece of art on itself! Just beautyful.
Thank you!
In "DIY speakers" sometimes beauty is made inside, but it is "heard " outside.
No, it's not a finish. Over the this white color will be finished with vener.Nice job with the white finish!
Thank you, but they are just in addition to the front speakers.These are not speakers, they are works of art!
Clarification, this is a polyurethane primer, follows the cabinet's veneer with "Birds of Maple".
- DIY my dream come true and ...go!
