PeeCeeBee
I am sorry, I think I miss something. How to measure bias on V1.1 and preferable mA ..
thank you.
Best regards
VAS bias is measured around any of the two 10R resistors closest to VAS transistors. Set multimeter to "mV" and measure the voltage around one of these resistors. Divide that reading by 10 and you get VAS bias in mA.
10mA is a good bias. So you would want to get a reading of 100mV around each 10R VAS resistor. Turn the trimmers slowly in small steps for that. If turning one of them seems to increase or decrease the VAS bias too far from 10ma (i.e. 100mV) then leave that trimmer and turn the other one.
MOSFET bias is auto-set by the two 1N4148 diodes between 150mA and 200mA.
Hi shaan,
Would you be considering v2 version of v4 anytime
Also any recommendation on power supply
Ajit
Hi Ajit.
Currently no plan for a high power version.
You can use any basic dual rail PSU with V4 as well as more sophisticated ones. A bank of minimum 20,000uF per channel is recommended.
A suitable PSU PCB for all peeceebees including V4 is under development. Will be available next month if everything works as expected. 🙂
Hello guys.
Here are the schematics for the V1.1 and the new V2 layouts. (sorry for the delay 😱 )
Thanks to everyone for making the PeeCeeBee thread what it is.
Also thanks admin for the warning. Disaster avoided! 😀
shaan
Hi Shaan,
For the V2 build with +/- 48 to 50 VDC,
I have
1. for the 1000uF - I have 220uF 63V
2. for 2200uF - I have 2200uF 25V
3. for 470uF - I have 220uF 63V
I am guessing (value-wise and voltage-wise), these should be ok, but would like to have your opinions.
reg
Prasi
Here is my V2 build.
used nichicon 220uF 63V for rail decoupling
i/p decoupling, used nichicon gold kz 220uF 63V
and for feedback, used keltron 2200 uf 16V.
funny, esr was lowest for keltron😕 and value was very very close to the nominal value🙂..
just finished soldering , yet to clean the bottom😱. I hope I dont run into problems. fingers crossed for testing.
Nice!
What is the code for these insulated fastons?
Are they pressed together with the insulation material or without them?
Nice!
male part TE connectivity 1742686-1
female part TE connectivity 3-520406-2
very nice quality and perfect. male part has stability protrusions at bottom ( see the curved protrusions at pcb mounting surface). aliexpress stuff is filthy and flimsy.
if you have nice Stanley crimp tool, you are good to go with any amp build that uses fastons. just buy it blindly.
the female part comes with faston receptacle with insulation. insulation part is detachable but with some difficulty.
so very safe.
Prasi,
Maybe this will help.
Hi Rick,
thanks for sharing.
I built PEECEEBEE V1 using same guidelines.
and same used for v2build.
I would like to know whether the bias is ok for v2. seems much much less as compared to V1.😕
I thought lats have optimum bias at 160 mA. VSSA, PEECEEBEE and Apex FX-8 that i built used about 130 -200 mA.
the joy was somewhat short lived.
while listening music, there was some sound and fire😀. I immediately hit the main switch.
bad resistors that shorted?😕
or problem with MJE's?
bottom side is quite fine.
same pattern of burning on both sides!!
