From the messages I got, it seems that people still do not understand how MAYA can be used along BPBP and which are the benefits.
Hans Polak did a great job by writing an extensive description in below thread. I invite all interested to read and digest.
Remote Control for the BPBP
Tibi
Thank you Tibi.
Hans
Thank you as well, Hans !
Your support to this project and not only, is very much appreciated !
Brgds,
Tibi
Brgds,
Tibi
24h sale start now. MAYA volume controller and MAYA for BPBP are now available at vicol audio : Webshop
Tibi
Tibi
Tibi, I have a couple of Maya boards bought for BPPBP already. Can I purchase and add a Bluetooth module myself with the firmware installed (LCD v 1.2. I think) and also the power relay ?
Yes. Please mail me.
Brgds,
Tibi
Hello
I am interested in one pcb kit plus integrated circuits and programmable controller
Hi Tibi,
I ordered (and payed immediately through PayPal) the BPBP version of the Maya controller during your "March 31st sale", but haven't received a shipment notice yet (or anything else) although you stated, that all orders would be shipped within "2 weeks" starting March 31st. This time frame has passed already.
I placed my order (and payment), which has been confirmed immediately afterwards, a few minutes (March 31st, 07:57 AM) before you even announced here, that the sale had started "now" (March 31st, 08:00 AM).
I am wondering, what happened to my order ?
Question to other buyers ("sale") : Have you received a shipment notice already ?
You know you can contact Tibi and Vicol Audio privately and directly don't you? That would be the norm for a commercial transaction, to contact the company.. going on a public forum suggests some kind of anger and shaming mentality?? Which is passive agressive and can get people's backs up and defensive before you've even asked the question about your order!
Of course it's your choice to act as you wish..
Hi Tibi,
Your order and few others will be shipped on 18. April, first day after Orthodox Easter. I apologise for delay.
Best regards,
Tibi
Just got an Android phone and tried to use the BluThor App with Maya. I can not get it to pair. Any trick to this? It just keeps saying unable to pair because of incorrect pin.
There is no way to enter a pin on my phone. From what I've read, you need to put the bluetooth device into "pairing mode". I've not found any documentation on Vicol website. Tibi, please help!
I believe now that I've been trying to pair with some other device. The Maya bluetooth does not show up on my phone.
Hi ,
please scan bluetooth devices , you should find one device called : Maya.
If you do not found that device please be sure the board with bluetooth is securely attached to main board .
All Maya sell by us have been tested that bluetooth work .
Best regards.
Pin is 1234.
On your phone go to settings, start bluetooth, scan for Maya and pair with above pin. Than start Maya android app, push upper left button and select again MAYA.
Tibi
Hi ,
Best regards.
Nope, nothing comes up. The board is fully seated. I've been using the controller for some time with the bluetooth board off since I previously did not have an android device. Could that have caused a problem?
My phone is a Moto G5. I also tried several i devices as well as a Macbook. Nothing sees the Maya bluetooth.
When listening to music it would be really cool if the display could be set to turn off after a set period of time. Just a suggestion but something I would really like.
Module we use is not a LE one. Therefore I need to test with a Macbook as well.
It is strange as each module was programmed and tested ...
At this point all I can do is to send you a replacement. Can you return BT module ?
Tibi
This function is implemented in LCD version. It could be implemented on OLED but will add a slight delay on power on.
Tibi
On public demand here is the testing version of software for MAYA with OLED display that turn off display after 1 minute of inactivity .
Please test all and feedback to me if you see bug .
version 1.3
(also some cleanup in code included)
will go to 1.4 once is tested
For this option to be enabled you must go in --->Settings--->"Ena/dis temp sh" and turn encoder to set : "nosh temperature" the setting will be saved in Eeprom the press Select till "exit settings" and turning encoder to exit.
The idea is that if you want to see temperature you do not need to power off oled display
but if you do not need that temperature you will be able to use this power off of Oled display feature.
- Group Buys
- Maya R2R Advanced Volume controller
