Moode Audio Player for Raspberry Pi
Just tried it here. Playlist file is not being saved.
Phil
@Phil, @Rob,
Just tested on Pi that runs the release image and on another that was bumped to 3.6 via in-place update and no issues.
After saving a playlist the file is written to /var/lib/mpd/playlists directory. Verifying via ssh that the file was successfully created would rule out a bug in that particular routine.
Btw, the bug that was fixed in 3.6 was that the save button was dead.
-Tim
3.6 installed, used Update in System Config , needed manual reboot via ssh, probably because I didn't wait long enough for Reboot Needed flag.
Pi3 with HiFiBerry Digi+ Pro. LL Kernel, CPU on demand.
Playlist save works fine. WiFi works fine.
Great work Tim, many thanks,
Ian
Hi Ian,
Nice!
I'd go for the Performance CPU governor unless you are tweeking for a low-volaage config and don't want to run the CPU at max frequency.
-Tim
@Phil, @Rob,
-Tim
Did an in place update from 3.5 and it doesn't work. No file saved, save button still dead. How can I force it to re-update?
Or which file needs editing so I can try to fix it myself?
Oh, looks like a browser or caching issue as it works from my laptop, but not my phone.
I'll investigate further.
Phil
Phil
Hi Phil,
Well, in-place updates that bump to next version can't be re-run without major sugery, but if you are up for it send me an email.
Some things to check to verify that the update was complete:
1) Moode About should show
Release: 3.6, 2017-04-23 release notes
Update: (None)
2) ls /var/local/www should have the following file
update-r35.txt
and it should not have the file update-r35.zip or a directory named update
3) The file /var/local/moode.sqsh will have the following file size
194007040
-Tim
Seems to be a browser related thing. If you clear chrome process then open Moode again- it works even with Chrome- but it isn't possible to save an individual playlist- name- independent of which browser one uses. I only got ' radio station' despite I typed RADIOSPEICHER for saving
Can't get it to save in Chrome on Marshmallow under any circumstances - even after clearing Chrome's cache and rebooting the phone.
Hi Tim!
You might be right! If I type big letters like 'RADIOSPEICHER' as playlist name, stations are saved as 'radio station' which you cannot delete. It shows like a radio station under 'Radio' in the browse- area.
If I type 'Radiospeicher' as playlist name- it works with no issues;-) mystical.
Greetingz
