Salas DCG3 preamp (line & headphone)
Yes - in Oslo this weekend. This is the latest iteration of Orpheus. Many hifi-shops have their "spring hifiparty" this weekend 🙂 The main attraction was this Orpheus HE-1. It actually was on TV this morning.
VGTV
(Sorry it is in Norwegian).
Salas,
I hope you wouldn't mind my intrusion.
I wonder what made you choose a cascoded IRFP9610.
I am sure you must have tried many others before settling on that choice.
But the IRFP PMOS is known to have this strange behaviour as pointed out by Charles years ago.
Did you try e.g. the 2SJ79 as in the Borbely (low capacitance enough to do without cascode) ?
Or even a 2SJ313 which is also quite low in C, and can live with 2V Vgs at 120mA bias.
Thank in advance,
Patrick
Salas,
Thank in advance,
Patrick
It measured better THD in this circuit even vs Fairchild FQP3P20 cascode. The IRF9610 seems showing more gfs in low current like 0.1A - 0.15A than some others in its light capacitance category from that result. There is gain in the output stage its not a follower so any little crss is bound to be multiplied >>2X. Thus a single TO-220 P-MOS choice would not go far. With such a weak driver stage at least. The discovered kink is for N-Channel of IR original manufacturing only maybe? Post #7 http://www.diyaudio.com/forums/pass-labs/48930-irf9610-matching-manufactures.html
Reactions: Russellc
Spring time and my job needs me twelve hours per day... But I had some progress. Top cover is almost finished! Believe it or not, I' ll have to install two more leds inside the box. I'm going to power them directly from DCSTB output. Would this affect performance soundwise? Should I preffer the positive or the negative rail for some reason? Or put one led on each rail for symmetry? I guess this is another annual award question😀
