Cheap TPA3118D2 boards, modding them and everything that comes with it
No, because the Volt+ is running at 1MHz BD, thats why.
Another thing i'm interested in is the increased THD at around 1Vrms.
Setup:
PVCC: 19V
Gain: 20dB
Load: 4R6 resistive
Stock board, only changed inductors.
For this i tested several different inductors:
attachment.php
The influence of inductance is shown here, 10uH vs 15uH. The "bubble" is flattened and shifted to higher levels:
attachment.php
Different geometries/material at the same inductance:
attachment.php
Lower inductance will shift the "bubble" a bit to the lower end:
attachment.php
Surprisingly the small Codaca CSD1013B dual inductor performed really well, even compared to its more expensive competitor from Coilcraft, the GA3416.
attachment.php
Compared with fig.8 of the TPA3118 data sheet (yes it's BTL), the cheap clone is close to EVM performance with the MSS1278-10uH yet. But of course, comparing PBTL with BTL at the different PVCC/Gain settings isn't accurate.
If now we can get rid of the bubble please.
Being close with pbtl and with mss-inductor also to btl 3251evm with same inductors already is very good. Board is a little small to easily implement a compact, I know you like them, bootstrap snubber/ prefilter snubber 🙂
Main ceramics in outputfilter probably cause some distortion, because also TI tells us. And TI doesn't use single ended input testing/measuring.
The high esr inputcaps they use might help grounded negative (in single ended) input too ???
Anyone wants to join in?
Mainly 0402 components.
Selectable Gain (20-36dB) 0R-Jumpers
Selectable fSW 400-1200kHz 0R-Jumpers
BTL/PBTL 0R Jumpers
2u2F Softterm input coupling caps (low noise, automotive)
PBTL with parallel inductors (2x2) 0R Jumpers
Diff/SE Inputs
Anti-Pop-Circuit
BS-Snubbers
EMI-Snubbers
AGND island for AFE
AVCC RC-Filter
LC-Filter or Ferrite+C filter or filterless
Master/Slave/Daisychain synchronisation
44x35mm (Length x Wide)
High-Current connectors for PVCC and outputs 2x3 Snap-in
4x M3 (3.2mm) mounting holes
Mute/Shutdown input
opt. LED for power/fault
opt. hickup-mode
No polarity protection
Smaller than Volt+
attachment.php
🙂 It is funny to see that opinions have changed. Your design lacks the cap multiplier though.
If you are looking for testers....
What/Which opinions have changed?
I have no opinion about the Volt+, i still just wonder how they achieved this THD-levels at 1MHz..😎
I'm pretty sure it's not the cap multiplier. (Or as others have mentioned, it doesn't help much with noisy SMPS)
I will have the testing done at 400khz soon just to see..
Also I spoke to the team...this level of THD+N that we achived...simple we took care of every detail on the PCB .Capacitors especially.
Thanks for the reply. I checked nearly every impact of the caps on those small 3118 PBTL boards contributing to the THD signature. Compared to the inductors influence was really small.
Looking forward for 400kHz measurements, as the signature "should" change" as well as the overall level which is suspected to be lower than on 1MHz.
you earlier said this board will be produced by a manufacturer, not soldered by hand. Are you looking for contributors for the prototypes ?
At first i will solder some up by hand for testing, so if anyone is interested in a bare board (or two) let me know. (If just getting five or so boards, reordering a small batch is not than environment friendly.. )
I did another listening comparing 24V SMPS and Kingrex PSU.
I may have mistaken hum for noise...:sorry:
So it still could be the cap multiplier doing things better.
BTL/PBTL 0R Jumpers
Diff/SE Inputs
Anti-Pop-Circuit
BS-Snubbers
EMI-Snubbers
AGND island for AFE
AVCC RC-Filter
Mute/Shutdown input
opt. hickup-mode
Smaller than Volt+
attachment.php
I could be interested. What price are we looking at?
Sent from my Nexus 5X using Tapatalk
One more thing..how many layers on PCB for cheap boards and for your design ?
Is it possible that instead of looking for one mistake in the cheap boards you should look at multiple smaller problems that together add up ? Replace all parts at once and test again with everything changed instead of testing one by one. Synergy .
But yeah 1Oz not acceptable
Class D amp is by definition a mixed signals PCB. It is bad practice in mixed signals to use a 2 layer PCB , 4 layers thats the standard. Thats what Volt+ is using.
I think you will lose some THD+N right there...
400Khz data was uploaded at our usual thread.Surprising ..
